2003 Silverado R/S Problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35982
Printed Date: April 08, 2026 at 10:25 PM
Topic: 2003 Silverado R/S Problems
Posted By: madman1133
Subject: 2003 Silverado R/S Problems
Date Posted: July 21, 2004 at 11:40 PM
I hope some on can help me with my problems.  I have a 2003 Chevy Silverado LT not the base model and I am trying to install a Bull Dog 1100 R/S.  I have also purchased the 791 Bypass and the 456G databus module. First of all everything seems to function right execpt the check engine light is on and the doors chime real fast after I unlock and open the door.  I have been reading articles online about the Ignition wires all needing to be hooked up correctly to fix the check engine light.  What I dont understand  is what I could have done wrong here since I also purchased the igntion harnese from bull dog.  So I didnt have to splice any ignition wires in the truck.  As for the door chimes any suggestions here would be greatly apprecated.  To me it almost seems to have something to do with the door triggers since it starts as soon as I open the door.  Also, the only way to get it to stop is to relock the doors with the drivers door open then unlock.  This clears the chime.  Any help would be greatly apprecated...  Just to add to the confusion I completely disconnected the door triger wire on the 1100 just to see if it would fix the problem.  This did nothing..
Donny
Donny S Williams
Posted By: sroth140
Date Posted: July 22, 2004 at 1:52 AM
it could be chiming if the lights are still flashing.  its the parking lights being on and the door open.  just an idea.
whats the other problem?  no remote start?  did you install a passlock II interface?
MECP certified installer
Date Posted: July 22, 2004 at 8:31 AM
That makes sense about the parking lights being on, I will check that today. The remote start works fine and the passlock II interface (791 Bypass) was installed without a problem. For some reason after starting the truck with/without the remoter starter the Check Engine light keeps coming on. I am going to hook up a computer tonight and get the error codes. I was just wondering if someone had any idea as to what to look for?
Donny
Donny S Williams
Posted By: Velocity Motors
Date Posted: July 22, 2004 at 10:05 AM
Test to make sure that the 2nd ignition output from the Bulldog unit is functioning properly.
Posted By: sroth140
Date Posted: July 22, 2004 at 12:48 PM
yeah check what Velocity is saying, on techsoft it says,
CHEVROLET, FULL SIZE PICKUP, 2003, Second Ignition
To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
i dont know why it would still happen with the key, tho.
Date Posted: July 22, 2004 at 6:17 PM
So this Ignition wire should only have power while cranking or while the key is in the run position?
Donny S Williams
Date Posted: July 22, 2004 at 8:46 PM
Do you think its safe to drive my truck to advanced autoparts to have the computer checked?  I was going to buy the ODBII Scanner but its 150 bucks.
Donny S Williams
Posted By: sroth140
Date Posted: July 22, 2004 at 11:29 PM
true ign wires have voltage in run and crank.  accy had voltage in accy and run, but drops out during crank.
Posted By: defective
Date Posted: July 22, 2004 at 11:51 PM
The reason the engine light is still on is 'cause the truck stored the OBD code, when the guy at the dealership (or yourself) checks the code, they can also clear it.   Try disonnecting the battery for about an hour, this also works (remember your theftlock code!!!!)
Posted By: kgerry
Date Posted: July 24, 2004 at 1:48 PM
also a lot of the OBD codes disappear after so many ignition cycles...you may find after a day or so it goes away by itself.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
