Hornet 732T & 451M in 98 Dodge Ram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36116
Printed Date: April 11, 2026 at 9:10 AM
Topic: Hornet 732T & 451M in 98 Dodge Ram
Posted By: cspot
Subject: Hornet 732T & 451M in 98 Dodge Ram
Date Posted: July 24, 2004 at 10:44 PM
Considering this setup...main concern is the keyless entry....but I'm expecting the 451M to resolve that.
Any words of wisdom on this setup, or install issues I could come across, please pass them on.
Chuck
Posted By: auex
Date Posted: July 24, 2004 at 11:01 PM
No problems what so ever with this install, real simple in fact. Also if the vehicle came with remote keyless entry as an original option then you won't even need the 451M. If it did then the locks are a postive trigger system, if they didn't then they are reverse polarity and you will need the 451M.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
