Varad wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36188
Printed Date: May 11, 2026 at 8:40 PM
Topic: Varad wiring
Posted By: burnurass
Subject: Varad wiring
Date Posted: July 26, 2004 at 9:04 AM
hey guys, I tried searching and found some simliar topics...but no one ever came up wiht and answer.  Here's my problem, I have a '98 Honda Prelude with the Clifford Matrix RSIII alarm/remote start.  I have tapped the positive and the ground for the varad scanner.  Now the yellow wire on the varad scanner, that's the one i'm having a problem wiht. IT's supposed to be hooked up to the "ground when armed wire".   Do you guy sknow which one this is? I thought this was the orange wire..I tried both but it doesn't work.  What is activates is teh door sensor...the scanner leds woudl go off whenever I opened or closed teh doors. =)
So...anyone know which wire it is on the alarm? Thanks! I'm almost done..just can't find that damn wire....i stripped so many wires and I SITLL coudln't get it.  Thanks again guys
Posted By: thedoc456789
Date Posted: July 26, 2004 at 11:05 AM
it is the orange wire. you must install a one amp diode to drive accessories on this wire
Posted By: timmay
Date Posted: August 12, 2004 at 9:49 PM
i am having the same problem could someone post a picture of where to put the diode?
the orange wire goes to the starter relay i believe
can i just splice into that?
Posted By: auex
Date Posted: August 12, 2004 at 11:06 PM
posted_image
Like this.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
