Resistors needed for 2003 Dodge Durango?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36322
Printed Date: May 10, 2026 at 2:33 PM
Topic: Resistors needed for 2003 Dodge Durango?
Posted By: chrisdeaner
Subject: Resistors needed for 2003 Dodge Durango?
Date Posted: July 28, 2004 at 1:43 PM
I saw this post: https://www.the12volt.com/installbay/forum_posts.asp?tid=29672&KW=durango+wiring and was wondering if I have to add resistors to the secrurity system or if it will work without them?
Thanks,
Chris
Posted By: swamprat323
Date Posted: July 28, 2004 at 5:27 PM
Is it ask for them then you will need them.
Posted By: jaurora
Date Posted: July 29, 2004 at 12:18 PM
*****Lock requires a negative trigger through a 820 ohm resistor. Unlock requires a negative trigger through a 330 ohm resistor
MECP certified (If it really means anything)
Jeremy
Date Posted: August 15, 2004 at 8:04 PM
Are relays required?
-Chris
Posted By: auex
Date Posted: August 15, 2004 at 8:17 PM
Yes. Lights are a -trigger 1k resistor, relay needed.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
