03-04 accord wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36426
Printed Date: May 09, 2026 at 1:45 PM
Topic: 03-04 accord wiring diagram
Posted By: dexinefx
Subject: 03-04 accord wiring diagram
Date Posted: July 29, 2004 at 7:16 PM
Hi all, I was wondering if anyone out there had the wiring diagram for the 03-04 accord..I don't know if the 2000 one is still the same. I have an 04 accord...Any help will be fine.. Thanks.
Posted By: draasch
Date Posted: July 29, 2004 at 8:58 PM
Make:   Honda
Model: Accord
Year:    2003
Alarm
Constant 12 volts WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK / YELLOW IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH AHRNESS *
Dome Light GREEN/ RED (-) GREEN CONN. BEHIND FUSEBOX
Trunk Pin Switch BLUE/BLACK (-) DRIVER KICK PANEL REAR BODY HARNESS
Parking Lamp RED / BLACK (+) WHITE CONN ABOVE FUSEBOX
Power Lock PINK/BLACK GREEN CONN LEFT SIDE OF FUSEBOX #201
Power Unlock PINK/BLUE TEST FROM PASSENGER SWITCH
* Installing A Starter Kill Relay At The Ignition Switch Harness Before The Starter Wire Enters The Driver Side Fuse Block May Cause A "Check Engine" Light To Come On. Starter Wire Should Be Accessed After Fuse Block. #201 - See Negative Pulse Door Lock Diagram.
Accessories
Window Up D\ RED / BLK P\ RED / BLU D\ RED / WHT P\ RED / WHT @ EACH #211
Window Down F/ RED / YEL F/ RED R/ BLU/BLK R/ BLU/BLK MOTOR *
Ign Key Warn
Trunk Release YELLOW /GREEN (+) DRIVER KICK PANEL #231
OEM Horn GREEN/ YELLOW (-) STEERING COLUMN HARNESS
Headlights
OEM Alarm Arm
OEM Alarm Disarm
* Due To Multiplexing Window Wires Must Be Accessed At Each Window Motor But All Are Reverse Rest At Ground Type Circuits #211- See Reversal Rest At Ground Window Circuit Diagram . #231- See Positive Pulse Trunk Release Diagram -
Remote Start
Tach Signal BLUE/RED ECM/PCM AT CENTER CONSOLE *
Ignition #2 BLACK/ RED IGNITION SWITCH HARNESS ** #239
Ignition #3
Accessory WHITE/ RED IGNITION SWITCH HARNESS
Neutral Safety
Brake Light WHITE/ BLACK (+) SWITCH ABOVE BRAKE PEDAL
Reverse Light
Rear Window Defrost
#239- See Immobilizer Bypass Diagram. * Passenger Side Panel Of Console- WHITE 31 Pin Connector Pin #25 ** Data Buss Bypass Availible- DB-PKH3 -
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
