Please help fast!No brake lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36469
Printed Date: May 09, 2026 at 7:18 AM
Topic: Please help fast!No brake lights
Posted By: azcwgirl8
Subject: Please help fast!No brake lights
Date Posted: July 30, 2004 at 5:16 PM
Please someone, can you look at your dodge, and tell me the wiring order for the brake light switch(above pedal) on a 1996 Dodge Ram 1500.I had to replace switch, and lost the notes I made of the order they went into the switch itself(it needed new connector,the clips were broken off plug) so can someone please help me put my wires back in the plug!Pleaseee ive been pulled over already, and im quite annoying using hand signals! Thanks;)
Posted By: Velocity Motors
Date Posted: July 31, 2004 at 9:12 AM
I thought the brake wires were attached to a plug not hard wired into the switch ?
Date Posted: July 31, 2004 at 12:06 PM
Yes, Thanks, When I bought the truck someone had jerry rigged the plug, and the bracket that holds the switch.I had to replace both!
