Pro Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=3658
Printed Date: April 23, 2026 at 9:50 AM
Topic: Pro Start
Posted By: dfiddy
Subject: Pro Start
Date Posted: September 15, 2002 at 3:25 PM
I am in the middle of installing a "Pro Start" remote starter on my 95' Monte Carlo, 1 of 2 things 1) i can't find the tach wire...the manual says go straight to the coil...where is that and 2) when i use the remote to start my car the starter keeps on engaging it won't let off. does that have anything to do with the tach wire? Any help would be greatly appreciated.
Posted By: securinu
Date Posted: September 15, 2002 at 3:31 PM
wire is purple /white @ coil on enginejust follow all the spark plug wire to a square box that is your coil. good luck. and yes that is why it just keeps spinning the starter it has no idea the car has started.
Posted By: dfiddy
Date Posted: September 15, 2002 at 3:34 PM
i'll try that and see what happens...thanks eh!
keep it real...
