Viper 350HV Install Help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36652
Printed Date: May 07, 2026 at 8:18 PM
Topic: Viper 350HV Install Help
Posted By: stagger
Subject: Viper 350HV Install Help
Date Posted: August 02, 2004 at 8:16 PM
Hi, I just purchased a Viper 350HV.  I have a few questions about the install procress.
1st, I assume this model has a built in parking light flash relay, so no external relay will be needed?
2nd, Im only doing a basic alarm, no remote start, so do I have to worry about Ignition 2 and 3, or just cut a wire ignition 1 into the relay?
3rd, The manual says "Since the Shock sensor does not work well when mounted firmly to metal, we do not recommend screwing down the control module"  so should it just sit up in the dash, zip tied to something?
Thanks in advance....
-Rich
Posted By: sroth140
Date Posted: August 02, 2004 at 10:49 PM
no relay needed, there is a jumper for +/-
you only need the main ign
the shock sensor (isnt that in the brain on these alarms), is best when mounted to a firm wire harness with zips usually.  turn the gain up or down to compensate.
MECP certified installer
Posted By: gcorrea
Date Posted: August 07, 2004 at 7:22 PM
i have the same alarm on my truck but i dont fully rellik on the brains built in shock sensor you can plug in a dual zone dei shock sensor into the side port. make sure you use a dei sensor because anything else wont work.
gcorrea
