Toyota Rav4 Alarm, Scanner LED
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36725
Printed Date: May 07, 2026 at 5:10 AM
Topic: Toyota Rav4 Alarm, Scanner LED
Posted By: FRANCO90
Subject: Toyota Rav4 Alarm, Scanner LED
Date Posted: August 03, 2004 at 7:10 PM
Can any one help me i am trying to hook up a scanner LEd it has 3 wires red yellow,black red goes 12Volts+ ,Black is ground Yellow goes to starter kill wire thats the problem I can't find the starter kill wwire on my rav4 00016-30960-01 security control module thats what the alaem module says can any one help
Posted By: FRANCO90
Date Posted: August 03, 2004 at 9:38 PM
my alarm has a wire that kills the ignition does any one knows where the wire is and what color it is i am trying to hook up an scanner LEd it has 3 wires one red to 12Volt one black to ground and yellow one to yellow to ground out put (ignition kill)of alarm system the problem is i don't knowwhich wire is the ground out put (ignition kill) wire product is VS400p [img]https://images.etronics.com/products/varVs400p.jpg[/img]
Posted By: draasch
Date Posted: August 03, 2004 at 9:49 PM
what is the brand of alarm???/ ------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: FRANCO90
Date Posted: August 03, 2004 at 10:41 PM
I don't know it came with my rav4 its a toyota alarm I guess all i need to know which wire is IGNITION wire
Posted By: draasch
Date Posted: August 03, 2004 at 11:16 PM
look up under the dash and see if you can see the unit.... ------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Posted By: FRANCO90
Date Posted: August 05, 2004 at 9:22 PM
Ok I look and this is info I found Main Module part number 0016-30960-01 Security Main Control Module FCC ID ELVAR6A I hope that helps Can any one tell me what kind of alarm is this
Posted By: FRANCO90
Date Posted: August 06, 2004 at 11:53 AM
draasch Thanks for the help I figured it out Toyota makes this alrm model for the south east area they faxed me all the info I need thanks again
Posted By: Scott35
Date Posted: August 06, 2004 at 12:55 PM
Hey Franco can you fax me or scan me the info for TDS setup, I have been looking for it also.
------------- Tacomacrew
Posted By: FRANCO90
Date Posted: August 06, 2004 at 3:10 PM
Scott35 what is your location also what kind of ride do you have Sure I can I have alarm diagram and also how to set up your remotes is there any way i can summit this INFORMATION TO 12volt
Posted By: Scott35
Date Posted: August 06, 2004 at 3:12 PM
It is a 2001 Tacoma, but my brain has the same numbers as yours. If you can scan it send it to SScooter429@aol.com, if you can fax it, pm me I'll send you my number. Thanks Scott
Posted By: FRANCO90
Date Posted: August 07, 2004 at 11:39 AM
Scott Check your E-mail how do I added my PDF alarm files to 12Volt.com
Posted By: FRANCO90
Date Posted: August 24, 2004 at 2:22 PM
ok I am still stuck I am triyng to find ignition kill wire that goes from mine car alarm to my ignition wire . the problem I am g]having is this i cann't find Ignition wire. I am trying to hook up a Scanning led i will post diagramof alarm brain maybe some one could help my alarm has a wire that kills the ignition does any one knows where the wire is and what color it is i am trying to hook up an scanner LEd it has 3 wires one red to 12Volt one black to ground and yellow one to yellow to ground out put (ignition kill)of alarm system the problem is i don't knowwhich wire is the ground out put (ignition kill) wire product is VS400p I know that red wire goes to 12Volt Black wire to ground here is the problem Yellow wire goes ground output (ignition kill)of alarm brain
Posted By: FRANCO90
Date Posted: August 24, 2004 at 2:23 PM
I cann't find ignition kill wire from alarm to ignition wire??help anyone
Posted By: FRANCO90
Date Posted: August 26, 2004 at 2:08 PM
any ideas on how i can hook the scanner when alarm is on Need help thanks
