1993 Honda Prelude, Compustar 2wss-as
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36803
Printed Date: May 06, 2026 at 10:40 AM
Topic: 1993 Honda Prelude, Compustar 2wss-as
Posted By: lude2nr
Subject: 1993 Honda Prelude, Compustar 2wss-as
Date Posted: August 04, 2004 at 9:37 PM
I just installed this alarm and it is stuck in valet mode. I tried pushing I and III at the same time on the 2-way remote and it isn't working. Any suggestions? Thanks.
Posted By: Velocity Motors
Date Posted: August 04, 2004 at 10:03 PM
Have you tried manually getting out of valet mode instead of using the remote control ?
Posted By: lude2nr
Date Posted: August 05, 2004 at 12:06 AM
How would I do that?
Date Posted: August 05, 2004 at 6:06 AM
Insert key into ignition and toggle ignition switch ON & OFF 5 times within 10 seconds FAST.
Posted By: tcool
Date Posted: August 05, 2004 at 1:49 PM
Jeff, I don't think that works. That's how you put it into valet, but I think you have to use the remote take it back out of valet (I least I couldn't do it on mine). lude2nr- you might need to reprogram your remote. Does your remote work at all (does it lock or unlock your doors in valet mode)?
bzzzzttttt
Posted By: lude2nr
Date Posted: August 05, 2004 at 5:27 PM
I just installed a 2wss-as in my 1993 Honda Prelude. When I push the tach sense button it flashes saying that I have the wrong tach wire. I hooked the tach wire into the blue diagnostic wire on the passenger side strut. It worked the first time I pushed the tach sense button but it wont now. The keyless works and the siren chirps.
Also, I hooked in a window module that was on my old alarm and that isn't working either.
Can anyone help??  Thanks
Date Posted: August 06, 2004 at 6:34 AM
Have you tried starting the vehicle with what ever tach programming you have now ? Try it and see if it works. Post your results.
Date Posted: August 06, 2004 at 6:37 AM
tcool, your right. I didn't read the instructions all the way posted_image. The only way to exit Valet Mode is to press I & III for 1/2 second ( very quickly )
Posted By: lude2nr
Date Posted: August 07, 2004 at 3:09 AM
Now I can get it into reservation mode sometimes but not always. Also, when I do get it into reservation it still wont start. But, I know the ignition is coming on because all the lights on my dash light up and everything??
Posted By: lude2nr
Date Posted: August 30, 2004 at 12:02 PM
Hey, I have a DEI window module that is all hooked up but not working. I called Compustar tech support and they say I need a diode to make it work. Does anyone know what size of one and where to put it? Thanks.
