1996 Acura Integra Dome Light
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36810
Printed Date: May 06, 2026 at 7:45 AM
Topic: 1996 Acura Integra Dome Light
Posted By: elserpiente
Subject: 1996 Acura Integra Dome Light
Date Posted: August 05, 2004 at 2:03 AM
Hi, I am installing an alarm in a 1996 integra, but cant find the dome light wire, can someone point me in the right direction? thanks!
Posted By: raydawg357
Date Posted: August 05, 2004 at 8:16 AM
If you are trying to catch a door trigger, use this:
Door Trigger lt. GREEN/ red  -  driver kick panel
Notes: Looks like 14 awg wire but mostly insulation.
In the larger of two attached gray plugs in the lower kick near the firewall. If equipped with cruise control, the plugs are behind the module. To access, remove the lower bolt on the bracket holding the module and pull it up out of the way.
Do it right the first time
