DEI 530T with Factory Keyless entry?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36822
Printed Date: May 06, 2026 at 5:49 AM
Topic: DEI 530T with Factory Keyless entry?
Posted By: cyberduc748
Subject: DEI 530T with Factory Keyless entry?
Date Posted: August 05, 2004 at 10:44 AM
Is it possible to install the DEI 530T with the factory keyless entry from 2005 Subaru STi?
The car do not have the factory alarm. I'm still considering to add the factory security upgrade kit at $140 or go with Compustar 2wss at ~$250 (ebay). The 2005 STi already have the immobilizer built in even without the factory alarm.
Thanks indavance for any input.
Posted By: auex
Date Posted: August 05, 2004 at 3:51 PM
The 530T could possibly work with the factory keyless entry system but wouldn't work the way it was intended, such as roll up on arm and it would probably take a couple of tries to roll all the way down. It would be worth adding an alarm. Also I would go for an alarm that adds new remotes, factory remote range is nothing compared to the aftermarket generally.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
