2004 Tundra double cab, tips needed
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36847
Printed Date: May 06, 2026 at 2:02 AM
Topic: 2004 Tundra double cab, tips needed
Posted By: profuse007
Subject: 2004 Tundra double cab, tips needed
Date Posted: August 05, 2004 at 6:06 PM
-about to do 04 Tundra double cab for my uncle this weekend. i did an 01 tundra ahile back for a buddy of mine but this model is different. just found a diagram through the search, dont know what type of diagram but its not DEI.
-on the 01 tundra i remember using the distributorless coil on the #1cylinder for Tach. anyone know if it still exist? i dont want to go to the ECU located behind the glove. BTW am doin this for free and tryin to save some time.
-i got the diagram for the drlocks. anything peculiar about it?
-BTW, is the BECU easy to reach to and work w/? i got a lots of diodes i got to waste for the door triggers.
-anything else on the list that i should be aware.
-man, shouldve charge him for the labor... crap!!!!!
Houston,TX
Posted By: sroth140
Date Posted: August 06, 2004 at 2:28 AM
tach WHITE/ blue at ECM behind glove box.
all triggers can be found at The BECU (Body ECU), above the driver kick panel, towards the firewall.
or you can get the triggers by grabbing the key cyl. illumination wire at the key cyl.
good luck with the door locks, they are all sorts of goofy.  because it sucks so bad and i feel sorry for you here
https://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1070.pdf
use the sequoia guide.
MECP certified installer
Date Posted: August 06, 2004 at 3:47 AM
thanks for the heads up on the door trigger. thatll save me sometime.
the doorlock looks time consuming but it shouldnt be hard.
imma check out the tach on the individual coil
Houston,TX
