Crimestopper 2-Way AM Alarms Worth Having?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36872
Printed Date: May 05, 2026 at 9:21 PM
Topic: Crimestopper 2-Way AM Alarms Worth Having?
Posted By: carracr625
Subject: Crimestopper 2-Way AM Alarms Worth Having?
Date Posted: August 05, 2004 at 11:44 PM
I am looking @ Crimestopper alarms. My question is are the 2way AM alarms worth having? Will the signal travel thru the walls of my apartment building? I've decided that I want either the Securcar CS-2004DC II or the CS-2004TW1. They can be seen here:https://www.crimestopper.com/index3.html. The reason for this particular model is I have no need for remote start. And these seem to have all the features I want without paying extra for the r/s feature. If anyone has any experience with these type of systems, your input will be greatly appreciated. If the am 2way is worthless, I will go for the CS-2004DC II.
Posted By: kenmci
Date Posted: August 06, 2004 at 3:21 PM
Two way alarm systems are great, and most allow you to increase the range over a standard non two way remote.  Having said taht i would go with neither.  I have crimestopper in the past and i have found them to be unreliable at best.  I would recommend going with something from DEI, like viper, clifford etc.
Date Posted: August 06, 2004 at 4:13 PM
I appreciate the advice. I've had a clifford on my bimmer since '96. It was great while working, but it stopped working all together in '01. Not quite sure why, but I think it had something to do with my alternator going up & having to hot shot it over & over. Any idea where I can orger DEI products on the web? Every retailer around here wants an arm & a leg.
