Hyundai Tiburon Keyless Entry Install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36919
Printed Date: May 04, 2026 at 9:37 PM
Topic: Hyundai Tiburon Keyless Entry Install
Posted By: reaper1812
Subject: Hyundai Tiburon Keyless Entry Install
Date Posted: August 06, 2004 at 11:08 PM
I've been doing some research looking around if it worth taking my door panel off to try and install a keyless entry system I bought (Auidiovox AA-925).  I've seen some sites that say you need to install an actuator (maybe that is if the car does not have power locks all ready).  Anybody had any luck putting a keyless in a Tiburon?  The wiring diagrams at the site show everything else I need to know, just need to get familiar with this part.  Looking around Hyundai's techincal database it looks like the actuators are 4 wire revese polarity, and I see they have the basic wiring diagram for that on this site.  Speaking of which, are they any good books out there for the Tib?  Mine did not come with a manual, and allegedly its out of print, and Chiltons doesn't make one either, any others?  Thanks for the help.
2000 Hyundai Tiburon, with power locks installed.
Posted By: Javelin3o4
Date Posted: August 07, 2004 at 1:43 AM
do all your doors unlock or lock when you lock the drivers door? if so that would be why, alot of systems that work like that usually have to have a seperate actuator in stalled in the driver door so when you arm/dis arm it it will pull the lock and unlock/lock all the doors. here is a scosche doc on how to remove your door panels if your not sure.
https://www.scosche-cars.com/encyclopedia/hi141.pdf?userID=87cfacf2d3c9336a968aefd28e575459&vehicle_id=HI0047
Date Posted: August 07, 2004 at 9:30 AM
Yeah, when you hit the lever on the driver side(not even a lock unlock button), it also locks the passenger side. I'm attaching the link for the wiring diagram from Hyundai's website. At first I thought I could use the actuator wiring diagram and catch 2 and 4 and that would trigure the actuators on both the passenger and driver side.
Date Posted: August 24, 2004 at 8:21 PM
I have only a couple of wires left to do in this install, the door sense and the light flash.
Allegedly, I have a negative door sensing system, yet when I get a probe on the two wires in the kick panel to ground(BLACK/ white and GREEN / WHITE on the diagram), it floats when the door is open and shows +12v when the switch is activated, is this the way it is supposed to work?
posted_image
My next question is about the kick panel, it is the raceway that goes from the front of the car to the back. When I connect to the green white wire in that raceway (as described in the list on this site), it only operates the turn signals, not the parking lights. Looking at this diagram it looks like I need to connect to the pink wire in that raceway, but I don't know if I am reading it right.
posted_image
Any help would be appreciated.
Posted By: draasch
Date Posted: August 24, 2004 at 8:34 PM
Power Lock ADD ACTUATOR ADD ACTUATOR TO DRIVER DOOR #204
Power Unlock ADD ACTUATOR ADD ACTUATOR TO DRIVER DOOR #204
#240- See Adding Actuator Door Lock Diagram.
Dome Light BLACK/ WHITE (-) DRIVER KICK PANEL
Parking Lamp GREEN / WHITE (+) DRIVER KICK PANEL
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: grn99cav
Date Posted: October 23, 2004 at 5:42 PM
Ok. I'm bringing this back from the dead because I'm having some of the same problems.
I'm working on a 2001 Tib and I've never worked with actuators before. So I'm taking it to a shop that my friend works at to get that done.
Now my other problem is I got the wire colors down, however when I go under the dash and to the DKP I see like 6 BLACK/ white wires (door trigger) and 4-5 GREEN / WHITE (parking lights). I tested them all with a DMM and none of them were responding. WTF? Can someone be more specific of where they are? is it behind/under the fuse box down there or what?
And my last problem, where is the best way to get through the firewall for the siren hookup?
Date Posted: October 23, 2004 at 9:15 PM
The door sensor should read 12 volts in relation to ground when you press the trigger in your door jam. I ended up using the pink wire in the the kick panel raceway next to the drivers seat for the parking lights, it should read 12 volts in relation to ground when you turn the parking lights on. I found the door sensor wire in that raceway as well. There should even be two in there, one going to the sensor and one going back. I didn't have a siren, so I can't help you there I just used the horn. I thought I saw someone post something about that though, I think they said if you have an automatic there is an opening where the clutch pedal is supposed to be. The wire colors is of course dependent on them keeping the wire colors the same from 2000 to 2001.
Posted By: grn99cav
Date Posted: October 24, 2004 at 7:04 PM
ok. as for the horn, I looked at all the wires coming from the steering column and found the BROWN / red wire that was supposed to be the horn. It should read ground when activated. but when i tested that it read ground even when the horn wasn't on... aaarrrrgg.
Date Posted: October 24, 2004 at 7:18 PM
The horn wire is really pink/white i think.
There are two wires (ground, signal from the horn switch) and they are isolated from all other wires (I think it is encased in a black case, or maybe the yellow corrugated tube, but I was thinking that was the air bag). I had to take the upper and lower plastic casing off to see those two wires. To tell the truth, it took me an hour to do the power, and engine on wire, but it took me the whole rest of the day trying to figure out the horn. There should be a little clip you can undo to take the wires away from the car so you can splice them easier. The easy way to test your new splice is to touch it to anything metal, or grounded. Hope this helps.
Date Posted: October 24, 2004 at 7:20 PM
posted_image
Here is the diagram I tried to post last time.
Date Posted: October 24, 2004 at 7:23 PM
OK, this is retarded I can't edit my screw up. I had to take the top and bottom off the steering wheel to see the two wires for the horn, it should be tucked away right behind the steering wheel on the bottom.
Posted By: mo12v
Date Posted: October 24, 2004 at 7:25 PM
It's not that difficult, U do need to add 1 actuator to mimic U Locking / UNLocking door which is hooked to your Keyless Entry
HORN is   BLACK/ White:
Constant 12 voltsRED / BLUEIGNITION SWITCH HARNESS
Ignition 12 voltsLT/GREENIGNITION SWITCH HARNESS
StarterTAN/BLUEIGNITION SWITCH HARNESS
Dome LightVIOLET/ORANGE (-)AT GENERIC ELECTRONIC MODULE *
Trunk Pin SwitchWHITE/ VIOLETAT GENERIC ELECTRONIC MODULE *
Parking LampBROWN (+)AT PARK LAMP RELAY
Power LockADD ACTUATORADD ACTUATOR TO DRIVER DOOR
Power UnlockADD ACTUATORADD ACTUATOR TO DRIVER DOOR
* Generic Electronic Module Is Located In The Center Console.
Accessories
Window UpWHT/BLACK
Window DownRED
OEM HornBLACK/ WHITE (-)STEERING COLUMN HARNESS
Remote Start
Tach SignalBUILT INTO PASSEGNERS
Ignition #2L BLUE/BLUEIGNITION SWITCH HARNESS
Ignition #3
AccessoryBLUE/BLACK & WHITE/ BLUIGNITION SWITCH HARNESS
MO
Posted By: grn99cav
Date Posted: October 26, 2004 at 1:57 AM
wow so now I have 3 different wire colors for the horn... I guess I'm just gonna try and get through the firewall for the siren... at this point, that seems to be the best/easiest way.
mo12v: that diagram is for a 2001 Tib, right?
thanks for your guys' help.
