Matrix RS 3.5 451m needed?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36924
Printed Date: May 04, 2026 at 6:32 PM
Topic: Matrix RS 3.5 451m needed?
Posted By: sesmith
Subject: Matrix RS 3.5 451m needed?
Date Posted: August 07, 2004 at 1:25 AM
I'm installing an RS 3.5 in a '95 Toyota Supra. The 3.5 came with a 451m relay. My car has (-) door locks so I didn't think a relay was needed. Can I just cut the 3 wire harness off of the 451m and wire it directly to the door lock/unlock wires? The install manual doesn't cover this.
Posted By: Javelin3o4
Date Posted: August 07, 2004 at 1:30 AM
if you dont require the relay just cut the small plug off the relay with the green,red,blue wires.
Posted By: sroth140
Date Posted: August 07, 2004 at 2:14 AM
yea, just dont use the red for anything.  its not strong enough of 12v unless its going to 86 of another relay.
MECP certified installer
