keyless entry for a toyota celica 2000
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36954
Printed Date: May 04, 2026 at 4:17 AM
Topic: keyless entry for a toyota celica 2000
Posted By: tannie105
Subject: keyless entry for a toyota celica 2000
Date Posted: August 07, 2004 at 3:54 PM
hmmm... i was just wondering if anybody here knows how to install a keyless entry on a toyota celica 2000?
antoine
Posted By: draasch
Date Posted: August 07, 2004 at 5:04 PM
its a walk through the park! we can walk you through it:
Make:   Toyota
Model: Celica
Year:    2000-01
Alarm
Constant 12 volts WHITE & BLACK/ RED IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ ORANGE IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH HARNESS
Dome Light RED / WHITE (-) AT BODY ECU
Trunk Pin Switch L GREEN (-) AT SWITCH OR DOME LIGHT IN TRUNK *
Parking Lamp GREEN (+) 10 PIN CONN ON BACK OF FUSE BOX **
Power Lock BROWN PASSINGERS KICK PANEL #201
Power Unlock YELLOW/BLACK OR BODY ECU *
* Can Also Be Found At The Body ECU On Right Side Of Center Consle. ** Must Remove White Junction Box to Access Parking Lt Wire. #201- See Negative Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
