How to disable oem security 2004 honda pi
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37109
Printed Date: May 01, 2026 at 8:28 PM
Topic: How to disable oem security 2004 honda pi
Posted By: DOHOA
Subject: How to disable oem security 2004 honda pi
Date Posted: August 10, 2004 at 9:59 AM
I am installing the remote start to 2004 honda pilot ,I need some help to disable the factory security.I have wiring information already but I still not sure in which wire and location to find the wire .should I hook to keysense wire (blue) from ignition harness or (blue) from driver door key cylinder. I also have question about the power door lock wiring can get from the box from passenger side kick can I get the wire to disable factory security from it too?, Thank you
Posted By: Velocity Motors
Date Posted: August 10, 2004 at 10:18 AM
The wire can only be access through the driver's door key cylinder for the OEM disarm. There is a module located inside the door and willmeter only with the key in the cylinder.
