96 accord door lock problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37168
Printed Date: May 01, 2026 at 12:20 AM
Topic: 96 accord door lock problem
Posted By: alexcvn
Subject: 96 accord door lock problem
Date Posted: August 11, 2004 at 10:01 AM
Hi, I'm trying to get the power door lock/unlock to work with the alarm's remote, but didn't happen. I uploaded a picture of the diagram, please follow link below to take a look. There are 4 choices of wiring to follow on the diag. , the 1st and 3rd one which I think are for my power door. Right now i'm on the 3rd one that I boxed. I'm pretty sure I followed the correct wiring.  Green wire is "up" so I connected it to the orange unlock wire, and Blue wire is "down" so I connected it to the BLACK/ white lock wire. On the diag. says "Motor" ,does that mean the "door lock control unit" which I found on my driver's side door. After I connected all the wires, if i manually use the control switch then it will work but if i use the alarm's lock/unlock remote then nothing happen. Please, any idea of what I did wrong, let me know. Thanks a lot.
https://www.geocities.com/tieuphithu/alphaguards.jpg
Posted By: raydawg357
Date Posted: August 11, 2004 at 11:22 AM
What type of alarm is it?  Your vehicle has (-) locks so all you have to do is connect the unlock wire from the alarm to the orange wire and the lock wire to the BLACK/ white wire.  Both of these wires are in a gray plug that is taped to a harness above the driver's side kick panel.  Make sure your alarm has a negative output for the locks.
Do it right the first time
Posted By: alexcvn
Date Posted: August 11, 2004 at 4:16 PM
Ive tried to hook up the alarm's wires to the lock/unlock door's wires above driver kick panel. It didn't work. It didn't do anything when I press the remote.
Posted By: alexcvn
Date Posted: August 11, 2004 at 5:09 PM
Should I add relays? According to the diag. provided with link above, it doesn't tell me the wires are (-) or (+) output. All it's saying is; green to unlock, and blue to lock. If so, could someone show me how to add relays to get the door lock/unlock remotely. greatly appreciated.
Posted By: profuse007
Date Posted: August 11, 2004 at 6:28 PM
does ur alarm unit say anything else for the door lock wires?
like NO, NC, common, 85,86,87,87a......?
Houston,TX
Posted By: draasch
Date Posted: August 11, 2004 at 11:02 PM
also make sure you use a meter to find the right wires
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
