Ungo SR5000 ignition wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37221
Printed Date: April 30, 2026 at 8:44 AM
Topic: Ungo SR5000 ignition wiring
Posted By: Nitropress
Subject: Ungo SR5000 ignition wiring
Date Posted: August 12, 2004 at 12:49 AM
I am installing an SR5000 in an older vehicle (1968 Mustang) that doesn't need or support the remote start function. I would like to completely omit the satellite relay and its harness, but I am confused by something in the manual.
It appears from all the wiring information that the yellow wire on this harness is the controller's ignition sensor, used to trip the alarm on Zone 5 and to sense ignition-on for programming, bypass, etc. I had planned to connect this wire directly to the ignition-on wire.
The manual says in several places that the (heavy gauge) pink wire in this harness must be connected for the override, programming, etc. to function. As nearly as I can tell, the pink wire passes the ignition-on signal (+12V) directly to the yellow wire except when the remote-start function is engaged.
Is this correct? If I omit the whole remote-start harness, will connecting the yellow ribbon wire directly to the ignition-on wire allow the alarm functions to work correctly?
Ad(thanks)vance...
Posted By: draasch
Date Posted: August 12, 2004 at 6:57 AM
i dont use that brand, but some alarms will use that harness as the main alarm inputs as well...why not just an alarm instead of a combo unit..... ------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: August 12, 2004 at 10:24 AM
I've had good luck with the brand, and I don't know of any alarm-only models that have all of the other features and incorporate the two-way fob. I want the advanced control, programming and alarm features, just not the remote-start.
