Auto Mate model 3
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37376
Printed Date: May 01, 2026 at 5:46 PM
Topic: Auto Mate model 3
Posted By: Rdking
Subject: Auto Mate model 3
Date Posted: August 14, 2004 at 10:19 AM
Hello all, I just purchased a car with the automate model 3 installed I have the owners manual and not the install guide. The alarm is set up for passive arming right now and I would like to change it to active. The info in the owners manual is to see dealer for programming. Can somebody post directions for changing from passive to active or tell me where I might find the install guide. DEI website only has the owners manual available.
Posted By: auex
Date Posted: August 14, 2004 at 11:37 AM
I couldn't find a "model 3" but this should still work.
1. Open door.
2. Turn ignition on then off.
3. Withing 5 seconds press and hold the valet button. After 3 seconds the horn will sound once to indicate the entry into the first features menu. To select the second features menu continue to hold the valet button until the horn soundse twice. Once thedesired menu is selected release the valet button.
4. Withing 5 seconds press and release the valet button the number of times corresponding to the desired feature. Then press the valet one more time and HOLD. The horn will sound the number of times equal to the feature selected.
5. While holind the valet button, select the feature by either pressing lock or unlcok button.
Menu 1 - lock Unlock
1 active arming passive arming
2 chirps on chirps off
3 Door error chirp off
4 Ignition locks ON Off
5. Panic enabled Off
6. Aux Output ACC output
7. Delayed door trig Instant trigger
8. Sensor shunt 2/4 All zones
9. 30 sec siren 60 second siren
10. 1 pusle valet 2-5 pulses
11 .02 horn duration .03, .04, .05 second
Menu 2
1. Ingition lock off
2. Ignition unlock off
3. active locks Off
4. .8 Second lock 3.5 sec pulse
5. Single unlock pulse double pulse
6. channel 3 validity second unlock
7. Codehopping on Off
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Rdking
Date Posted: August 17, 2004 at 3:37 PM
Hey Auex, I tried your instructions several times with no luck. After doing steps 1,2 and 3 I end up in the valet mode and not the programming mode. Do you or anyone else have any different instructions. The owners manual says that Active arming is default does anyone no how to reset to defaut of course this will probably screw the remotes then they will need programmed?
Posted By: Rdking
Date Posted: August 19, 2004 at 4:00 PM
Any help out there?
Posted By: extreme1
Date Posted: August 19, 2004 at 9:11 PM
is it a 3 or a 3 plus?
routine.
open drivers door..
turn ignition on / off
press valet button once
press and hold valet button (siren will chirp once)
while holding valet button, press button 1 on remote
siren will chirp once.
let go of button
turn ign on to exit programming.
------------- Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: extreme1
Date Posted: August 19, 2004 at 9:13 PM
if it's a model 3 (external shock sensor) you need to open the little door on the alarm and CUT the red loop.
Visions Electronics
Red Deer, Alberta
Posted By: Rdking
Date Posted: August 20, 2004 at 5:30 PM
Shaughn, I think its just a model3 no plus so your saying to change from passive to active arming all I have to do is cut the red jumper?
Posted By: extreme1
Date Posted: August 20, 2004 at 11:13 PM
that is what I am saying...
Visions Electronics
Red Deer, Alberta
