99 Chev PU doorpins
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37399
Printed Date: May 02, 2026 at 1:06 AM
Topic: 99 Chev PU doorpins
Posted By: forbidden
Subject: 99 Chev PU doorpins
Date Posted: August 14, 2004 at 5:36 PM
As stated, no keyless entry, what are the doorpins wire colors. I do not have the vehicle in front of me, it is for one of our remote customers way out in the toolies.
Posted By: tbirdman74
Date Posted: August 14, 2004 at 6:26 PM
Use tan for drivers door located in pinB4 of the purple plug, and for the passenger door, it will be an orange in pin B2 of purple plug, or dk.blue/white in pin B11 of the lt.blue plug, and of course you know to isolate with diodes. sorry, these plugs are the ones going into the BCM (body control module) behind drivers side dash, with the plugs facing the rear of the vehicle.  Hope this will help your customer out.
If it don't fit, Force it.
If it breaks, You needed a new one anyway!
Date Posted: August 14, 2004 at 6:37 PM
Thanks for the help, they were the correct wires.
Brian - not Rob, just using his login for a customer.
