2nd-Gen RX-7
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=3744
Printed Date: April 24, 2026 at 7:35 PM
Topic: 2nd-Gen RX-7
Posted By: omegamotorsprts
Subject: 2nd-Gen RX-7
Date Posted: September 17, 2002 at 11:42 PM
Ok so I've done a good amount of alarms but this will indeed be my first 2nd-Gen RX-7 and I'm sure that this kid is gonna want his keyless entry, am I reading right in assuming that this car does not come standard with power locks and will need an actuator, what else can you tell me thats handy about this cary. Thanks
posted_image
Posted By: Velocity Motors
Date Posted: September 18, 2002 at 5:32 AM
This is for a 1994 - 1996 RX-7
|              12V|BLACK/ green         |+  |ignition harness            |
|          STARTER|BLACK/ blue          |+  |ignition harness            |
|         IGNITION|BLACK/ white         |+  |ignition harness            |
|  SECOND IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|       POWER LOCK|add actuator        |   |in drivers door             |
|     POWER UNLOCK|add actuator        |   |in drivers door             |
| PARKING LIGHTS +|RED / black           |   |fuse box                    |
| PARKING LIGHTS -|gray                |   |steering column             |
|       HEADLIGHTS|WHITE/ blue *3       |-  |steering column             |
|     DOOR TRIGGER|blue/white          |-  |passenger kick panel*2      |
|  TRUNK/HATCH PIN|gray                |-  |switch or cpu #2 *5         |
|         HOOD PIN|BROWN / yellow        |-  |switch or cpu #2 *5         |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|dk.GREEN/ black      |-  |drivers kick panel          |
|FCTRY ALRM DISARM|lt.GREEN/ black *4   |-  |drivers kick panel          |
|       TACHOMETER|yellow/blue         |   |leading ignition coil*1     |
|       BRAKE WIRE|green               |+  |at brake switch             |
|     HORN TRIGGER|GREEN/ orange        |-  |column or cpu #2 *5         |
|           WIPERS|blue / YELLOW         |+  |steering column             |
|  LF WINDOW UP/DN|red - green         |A  |in drivers door             |
|  RF WINDOW UP/DN|blk/wht - blk/yel   |A  |in drivers door or dkp      |
Notes:
*1 Also found coming through firewall above brake.  Set module to the six(6) cylinder setting.  *2 Can also be found in the drivers kick panel above the relays.  *3 To operate the pop-up motors provide 12v to the WHITE/ green, also at the steering column.  *4 Has also been found to be a pale yellow/red on some models.  *5 CPU #2 is located in the left kick panel
