2002 ford excursion wiring info
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37482
Printed Date: May 03, 2026 at 7:33 AM
Topic: 2002 ford excursion wiring info
Posted By: jaurora
Subject: 2002 ford excursion wiring info
Date Posted: August 16, 2004 at 11:59 AM
Can some one help me out with a tech sheet for this vehicle. It is a 2002 Ford excursion diesal.
MECP certified (If it really means anything)
Jeremy
Posted By: profuse007
Date Posted: August 16, 2004 at 12:19 PM
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|yellow & lt. grn/pur|+ |ignition harness            |
|          STARTER|green               |+ |ignition harness            |
|        IGNITION|RED / lt. green       |+ |ignition harness            |
|        ACCESSORY|gry/yel & RED / blk   |+ |ignition harness            |
| SECOND ACCESSORY|blue/lt. green      |+ |ignition harness            |
|       POWER LOCK|WHITE/ red           |- |VSM *1                      |
|     POWER UNLOCK|BLACK/ white *4      |- |VSM *1                      |
| PARKING LIGHTS +|brown               |   |headlight switch            |
|       HEADLIGHTS|RED / yellow          |+ |headlight switch            |
|     DOOR TRIGGER|BLACK/ lt. blue      |+ |either kick panel           |
| TRUNK/HATCH PIN|pink/lt. blue       |- |VSM *1                      |
|       TACHOMETER|*2                  |   |ignition coils              |
|      SPEED SENSE|gray/black          |   |instrument cluster or *3    |
|       BRAKE WIRE|lt. green           |+ |brake pedal switch          |
Notes:
NOTE: This vehicle is equipped with PATS (Passive Anti Theft System). Use DEI module 555F to over-ride during remote start. *1 The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening. *2 For tach go to any one of the ignition coils and use the wire that is NOT RED / lt. green. On diesel vehicles the tach wire is green or white, in a 42 pin plug under the clamp on the engine side of the air intake duct. On diesel vehicles the wait to start light is activated by a databus wire from the ECM. To do wait to start use a pulse timer relay and follow directfax document #1091. *3 Also found at the radio on vehicles that have the in-dash CD changer. *4 The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to 'wake-up' the system refer to directfax document #1094.
Houston,TX
