viper 791 H2 wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37545
Printed Date: May 04, 2026 at 2:32 AM
Topic: viper 791 H2 wiring
Posted By: Flymase
Subject: viper 791 H2 wiring
Date Posted: August 16, 2004 at 10:45 PM
My secondary harness doesn't match what's in my manual. My harness goes as follows: (the manual uses the same colors but is a different order)
h2/1- light green black
h2/2- grey/ black
h2/3- GREEN/ white
h2/4- violet/ black
h2/5- WHITE/ black
h2/6- light blue
is my harness set up correctly and there is an error in the manual. I  just want to make sure that I'm making the right connections especially when it is dealing with disarming my factory alarm.
Posted By: auex
Date Posted: August 16, 2004 at 11:25 PM
Easy way to triple check is to check the diagram on the back of the brain as well. I have had some harness miss pinned, it does happen.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Flymase
Date Posted: August 17, 2004 at 7:47 AM
There is no diagram on the back of my brain. According to my manual H2/1 and H2/6 are correct should i ignore the colors for the other wires and line them up with the pin diagram in the book.
Posted By: mobilevt
Date Posted: August 17, 2004 at 9:45 AM
I got a Chevy Silverado 1500HD LS Crew Cab here to be installed with a Viper 791XV.  Is the truck sensitive to what kind of window roll up module and passlock module it can use?  I went and ordered a 555L for the bypass and 2 Smart window roll up module from asianwolf.com.  Will they work fine?
Sean - EVConcepts
Emergency Vehicle Technician
Got Freedom? Thank a vet!
Posted By: Flymase
Date Posted: August 18, 2004 at 4:50 PM
Any suggestions?
Posted By: profuse007
Date Posted: August 18, 2004 at 4:56 PM
for disarm wire, it shows (-) when unlock. check it w/ a DMM.
Houston,TX
Posted By: Flymase
Date Posted: August 18, 2004 at 5:04 PM
the wires on the harness won't read anything with a dmm. Profuse do you understand the problem that I have. My H2 harness is not wired up like it's suppossed to be.
Date Posted: August 18, 2004 at 5:24 PM
its only a diagram. but what i was sayin is that, out of those 6 wire, theres a disarm wire.
to confirm, the h2/1 is disarm wire. but if you want to be anal, test all 6 wires to make sure which give (-) when unlock.
Houston,TX
Posted By: BuckCJ85
Date Posted: August 18, 2004 at 5:55 PM
Search.  I had the same question a while back.  The harness is correct from the factory.  The pins are misprintet in the beginning of the installation manual.  The colors/uses are right, the pins wrong.  The overall diagram in the back of the book is correct and is identical to how the harness comes.
Posted By: Flymase
Date Posted: August 19, 2004 at 10:39 AM
Thanx buckcj85 I see that now. I appreciate the help.
