93 Civic brake switch wire location
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37559
Printed Date: May 04, 2026 at 3:16 PM
Topic: 93 Civic brake switch wire location
Posted By: elpiar
Subject: 93 Civic brake switch wire location
Date Posted: August 17, 2004 at 1:36 AM
Hi,
I'm in the process of upgrading my 92 civic alarm and remote start. In all database they tell me that the brake (+) light wire is GREEN / WHITE. It is not possible to reach and make connection in the brake switch, so I'm trying to locate them near the fuse box.
I was able to do this for my previous alarm. For whatever reason I cannot locate them now. The GREEN / WHITE that I found is not the correct one.
Anyone can help?
Posted By: elpiar
Date Posted: August 17, 2004 at 1:37 AM
Hi,
Anyone can help?
Posted By: raydawg357
Date Posted: August 17, 2004 at 8:36 AM
You will have to catch it at the brake switch.
------------- Do it right the first time
Posted By: elpiar
Date Posted: August 23, 2004 at 11:02 PM
I remember being able to use one of the connection at the fuse box connection (easier to access). Anyone has done this before?
It's really hard to reach to the brake switch in my civic, not to mention splicing and making new connections.
Any ideas to share?
Posted By: auex
Date Posted: August 23, 2004 at 11:04 PM
You can find it in the driver's kickpanel as well.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
