2002 Mitsubishi Airtrek alarm wiring plz
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37564
Printed Date: May 04, 2026 at 6:32 PM
Topic: 2002 Mitsubishi Airtrek alarm wiring plz
Posted By: ning6754
Subject: 2002 Mitsubishi Airtrek alarm wiring plz
Date Posted: August 17, 2004 at 12:58 AM
i do the car right now.....
2002 mits AIRTREK
all the wires was find out but just the door lock and unlock wires i cant find
plz...plz
Posted By: ning6754
Date Posted: August 17, 2004 at 1:15 AM
lock \unlock wires
plz plz help
Posted By: ning6754
Date Posted: August 17, 2004 at 4:11 AM
i was set the alarm for the 2002 Airtrek 5 doors lift back.
it has got the keyless entre system...think the factry one on the key
but i cannot find the wires for the door lock \unlock
Posted By: ning6754
Date Posted: August 18, 2004 at 6:20 AM
anyone can help?
Posted By: badnad
Date Posted: August 19, 2004 at 7:16 AM
i am an installer for AUTOWATCH CAR SECURITY new zealand. yes it is a bit tricky to get the central locking wires for the mitsi airtrek but there are 2 ways of doing it.
1) if the vehicle has a door motor in the drivers door (fully central locking) then you can do a FLOW THROUGH method where you can cut the drivers door motor wires and run them with the alarm system.
2) if you want to find negative switching, then you will have to take the central locking module (a big box behind the fuse box) open it and pick up 2 thin contacts which will be you negative trigger wires for the central locking.but be aware, in this method, you can easily burn the circuit board if you are not too carefull.
any problems, email me on badnadtrade@hotmail.com
I'll be back, so nobody go no where
