2000 kia sporage door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38107
Printed Date: March 31, 2026 at 11:27 PM
Topic: 2000 kia sporage door locks
Posted By: juancortezv
Subject: 2000 kia sporage door locks
Date Posted: August 25, 2004 at 9:31 PM
Any body can helpme on this,I gonna install a alarm,and I want to know if I have to use relays to electric door lock or just conected to the wires(2000 kia sporage)     Alarm (avital) Thank you.
Posted By: mo12v
Date Posted: August 25, 2004 at 9:37 PM
Power LockRED / GREEN (-)22 PIN SQUARE CONN ABOVE FUSE BLOCK
Power UnlockWHITE/ RED (-)
You could use Relays for a stronger Ground Output.  Some Alarms don't have enough output for Locks.......(500ma) or less
MO
Posted By: Velocity Motors
Date Posted: August 25, 2004 at 10:16 PM
I would try to go without relays first. This will save you time and money for the relays. If this doesn't work without relays, then go and find yourself some SPDT relays and wire both of them to the door lock system.
