92 deville trunk motor
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38198
Printed Date: May 15, 2026 at 12:08 AM
Topic: 92 deville trunk motor
Posted By: SoufBendMobsta
Subject: 92 deville trunk motor
Date Posted: August 27, 2004 at 5:45 PM
    the trunk realease on my 92 deville quit working, some guy told me there was a switch that could be replaced for like 40 bucks, he also said there was something he could do with the wires to the motor to make it shut as a quick fix, does anyone know how to do this?
Cadillac Chris
Posted By: daniel2002p
Date Posted: August 27, 2004 at 9:30 PM
if your trunk selenoid still works, then he was probably just going to wire up a relay and hook it up to a push pin swith.  if the selenoid still works, and just the wiring is damaged, it is no big deal fixing that.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
