VIper Alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38273
Printed Date: May 14, 2026 at 12:41 AM
Topic: VIper Alarm
Posted By: berniemac
Subject: VIper Alarm
Date Posted: August 29, 2004 at 9:43 AM
I was wondering if someone could get around an alarm by tapping the car enough to make the warn away go off and breaking the window while the warn away is still beeping? Then they could hop in through the window and work at disabling the alarm. I don't have any kind of interior motion sensors or glass break sensors. Would this work or would the full alarm go off when the shock of the window being broken is detected.
bernie mac
Posted By: auex
Date Posted: August 29, 2004 at 1:16 PM
Not in the way you described. If they hit the warn away then the alarm would still go full trigger on a larger impact. Now if they set the shock sensor off 3 times in an hour then the alarm would disable that sensor for an hour. During that time they could break the window and climb in with out a peep.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: tanz2004
Date Posted: August 29, 2004 at 6:08 PM
Buy a pressure switch for the Front seats and under the front mats. I have them in all my alarm setups and they are great. I did a sale-a-thon and sold upgrades and alarms with the switches in my area people don't know if they want or need something without showing them how well they work. When you install them make sure to use a diode between all the switches.
Also if you reset your Alarm at any time while your alarm is going off it resets the alarm. Only if you don't disable and re-enable the alarm does the system bypass the sensor trigger. If you have something to lose in your car always make sure to check it and reset the alarm if you are able to. Also without adding the pressure switches make sure when you un arm and re arm you can see you car/truck. some times theif's will use the alarm to gain access to your auto while you are re arming it.
TanZ2004
Washington State
