Bypassing clutch during remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38368
Printed Date: May 12, 2026 at 6:42 PM
Topic: Bypassing clutch during remote start
Posted By: Mattthew278
Subject: Bypassing clutch during remote start
Date Posted: August 30, 2004 at 9:10 PM
I'm installing  a Viper 550 into my truck and I need to bypass the clutch.  I had it set up before so the clutch was bypassed all the time but I wanted to change it.  I was reading through the manual, and it seems like I could use the "(-) 200 mA Status/Factory Alarm Rearm wire to activate a relay which could bypass the clutch.  My question is would the - output from that wire be sent out to the relay in time to have it activated before the starter was actually engaged?  Thanks in advance for your help.
matt
Posted By: profuse007
Date Posted: August 31, 2004 at 1:29 AM
yes it will be in time, youll need a relay to properly send a signal to the clutch wire.
Houston,TX
Posted By: vbel
Date Posted: August 31, 2004 at 10:20 AM
Hm, that's what I was also told, that I need a relay... I bypassed my clutch with directly connecting that wire to the clutch wire...if that's not enough, the same wire triggers my bypass module, at the same time. No relay needed.
Posted By: slipkx2
Date Posted: September 01, 2004 at 1:14 PM
make sure that you leave it outta gear or eles you may find yourself running after your truck with no way of stopping
Posted By: mo12v
Date Posted: September 01, 2004 at 2:03 PM
Hope U hook up By-Pass Relay on Emergency Brake also
MO
Posted By: xtremeaudio
Date Posted: September 03, 2004 at 2:14 AM
YOU THE DIODES THAT FAST AND EASY WAY IF DON'T WORK THEN YOU RELAY 87(-)86(+)30GO TO THE CLUTCH AND 85 GO TO ALARM
