prestige alarm in 2000 corolla
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38550
Printed Date: May 10, 2026 at 1:19 PM
Topic: prestige alarm in 2000 corolla
Posted By: huntr24td
Subject: prestige alarm in 2000 corolla
Date Posted: September 03, 2004 at 8:35 AM
i have a 2000 corolla with a prestige alarm installed but when i open my passenger doors alarm will not go off.  the dome light is on when i open the passenger doors and idea???? do i need to connect to another wire all i have connected is the brown wire to the door trigger on the drivers side.  also is it possible to use the trunk pin wire to trigger the trunk to go off even if i don't have power locks or that?
Posted By: auex
Date Posted: September 03, 2004 at 7:48 PM
You have only hooked up the driver's door.
directechs.com wrote:
Also found at the fuse box. There are at least 5 RED / white wires at the fuse box, some will only pick up individual doors, meter them to find the one that will get all the doors, it will be the one that goes up to the instrument cluster, it is in a 12 pin plug on the back of the fusebox. For domelight supervision use one of the individual door triggers.
What do you mean by the trunk pin/trigger? You can set the alarm off when you open the trunk, but you cannot open it unless you have a button or add a solenoid.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: another-kelly
Date Posted: September 04, 2004 at 12:31 AM
if you mean as far as just triggering the alarm then:
TRUNK/HATCH PIN | RED / white | - | light in trunk
or if you have a factory alarm, you can find this wire at the alarm module above the drivers kick panel.
otherwise it's like auex said.
Date Posted: September 04, 2004 at 9:47 AM
when i tired into the RED / white in the drivers kick panel and opened trunk the alarm didn't go off.  Also when i wired brown wire into the RED / white on the passenger side (to trigger passenger side) it never worked.  am i using the right wires?
Date Posted: September 04, 2004 at 9:48 AM
btw i'm not trying to pop open the trunk i'm only trying to trigger the alarm
Posted By: Velocity Motors
Date Posted: September 04, 2004 at 11:53 AM
There are at least 5 RED / white wires at the fuse box for the door triggers, some will only pick up individual doors, meter them to find the one that will get all the doors, it will be the one that goes up to the instrument cluster, it is in a 12 pin plug on the back of the fusebox. For domelight supervision use one of the individual door triggers. For the trunk trigger wire it's a RED / WHITE wire and the wire is located by the light in trunk ( On vehicle with the factory alarm, can find these wires at the alarm module above the drivers kick panel. )
Date Posted: September 07, 2004 at 2:25 PM
i need help.  my car won't come out of park?  any idea as to why.  i was trying to find door trigger wire and i i even took power wire from battery off and still wont come out of park
Posted By: xtremeaudio
Date Posted: September 09, 2004 at 9:56 PM
use dome light  wire that way open any door alarm will go off
Posted By: profuse007
Date Posted: September 10, 2004 at 7:13 PM
i had to metered a whole bunch of wires to find the correct one. i also used a relay to isolate domelight delay.
Houston,TX
