how can i plant in courtesy door light ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38617
Printed Date: May 09, 2026 at 10:25 AM
Topic: how can i plant in courtesy door light ?
Posted By: jemmy
Subject: how can i plant in courtesy door light ?
Date Posted: September 05, 2004 at 1:25 AM
i plan to plant in some extra light into my door panel. the light will go on as long as the door opened and it goes off when the door is shut.
i opened up the panel but i do know how to wire the light ...the car is ford escape 03
can somebody help me out wiring it exactly?
thanks a lot
Posted By: Velocity Motors
Date Posted: September 05, 2004 at 11:49 AM
You can use the existing door trigger wire ( PURPLE / lt green wire at the GEM module ) and this is a (-) trigger wire. Wire it to a relay that will trigger the lights that you are wiring up.
Posted By: jemmy
Date Posted: September 05, 2004 at 11:58 AM
i really don't know if i should ask this to you since i'm talking about a specific brand of car...
where is the gem located at? how can i reach it?
thanks a million velocity...
Date Posted: September 05, 2004 at 12:12 PM
The GEM (generic electronic module) is behind the center console on the floor. Pull off the black panel to the right of the gas pedal, there will be carpet covering it. The plugs face the driver side of the vehicle.
