94 civic ex unlock/lock wires
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38664
Printed Date: May 08, 2026 at 6:57 PM
Topic: 94 civic ex unlock/lock wires
Posted By: tsh30039
Subject: 94 civic ex unlock/lock wires
Date Posted: September 06, 2004 at 6:39 AM
i found a 2 pin male plug with blue tape GREEN / WHITE GREEN/ red but no female end that went with it is this the correct wire lock outputs.
Posted By: draasch
Date Posted: September 06, 2004 at 9:22 AM
should be.....test the wires with a meter..........
Power Lock GREEN / WHITE SWITCH OR DOORLOCK CONTROL
Power Unlock GREEN/ RED UNIT IN DRIVER DOOR #201
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: profuse007
Date Posted: September 06, 2004 at 11:19 AM
civics lock wires should be somewhere left of the dash and up there. just have to meter them!!!!
Houston,TX
Posted By: tsh30039
Date Posted: September 07, 2004 at 7:00 PM
thanks guys
