03 KIA Sedona LX wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38688
Printed Date: May 08, 2026 at 12:57 PM
Topic: 03 KIA Sedona LX wiring diagram
Posted By: deepseapassage
Subject: 03 KIA Sedona LX wiring diagram
Date Posted: September 06, 2004 at 4:56 PM
I am looking to install a Vared Alien LED without the use of an alarm.  I know it is a simple 3 wire conection, with a negative when ground.  The thing is I want to do this in the easiest possible way.  without  doing any damage to my van, and I am noyt sure what wires to use.  Would theradio be the easiest way???
thanks
anthony fong
Posted By: draasch
Date Posted: September 06, 2004 at 6:35 PM
Make:   Kia
Model: Sedona
Year:    2003
This Database Was Last Updated On:    4/7/2004
Index #: 1932
Alarm
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts WHITE IGNITION SWITCH HARNESS
Starter BLACK / YELLOW IGNITION SWITCH HARNESS
Dome Light BLACK/ L BLUE (+) AT LIGHT UNDER DASH
Trunk Pin Switch BLUE (-) AT MODULE BELOW GLOVEBOX
Parking Lamp WHITE/ RED (+) IGNITION SWITCH HARNESS
Power Lock WHITE/ BLACK IN DRIVERS #201
Power Unlock RED / BLUE KICK PANEL
#201 See Negative Pulse Door Lock Diagram.
Remote Start
Tach Signal YELLOW/WHITE UNDER RIGHT DASH 25 PIN CONNECTOR
Ignition #2 BLACK IGNITION SWITCH HARNESS
Ignition #3
Accessory GREEN IGNITION SWITCH HARNESS
Neutral Safety
Brake Light WHITE AT SWITCH ABOVE BRAKE PEDAL
Reverse Light
Rear Window Defrost
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: XMC SAM
Date Posted: September 16, 2004 at 3:08 AM
You can also get the dome light and trunk trigger at a thin long white plug at the back of the spedo cluster, Just reach up high behind the instrument cluster and pull out.
green= negative door trigger
GREEN/ black= negative trunk trigger
2004 Sedona has the same wire colors but in two differrent plugs at the rear of the instrument cluster.
