placement of proxy sensor
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38761
Printed Date: May 09, 2026 at 12:52 PM
Topic: placement of proxy sensor
Posted By: CutlassThunder
Subject: placement of proxy sensor
Date Posted: September 07, 2004 at 7:46 PM
Where is the best place to place a proxy sensor?
Posted By: raydawg357
Date Posted: September 09, 2004 at 2:06 PM
Headliner, center console, try to keep it in the center of the vehicle if possible.
------------- Do it right the first time
Posted By: sparkie
Date Posted: September 09, 2004 at 8:11 PM
Place the sensor against an area of metal atleast 6"x6". The sensor needs to be installed where it will evenly cover both sides of the vehicle. The sensor can't work through metal, so be sure there isn't any metal in front of the sensor. Make sure that what you mount it to is VERY solid. Mounting these sensors to the roof is usually a bad idea. Environmental conditions like wind can cause the roof to move slightly and cause the sensor to false. If possible, try to mount the sensor in an area where you can easily re-adjust it if necessary. Patience is a virture when adjusting proximity sensors. Take your time.
------------- sparky
Date Posted: September 10, 2004 at 7:34 AM
I'm thinking about Velcro and headliner thts how they had it done on my car before I took it off to sale the car...
