1999 camaro factory alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38814
Printed Date: May 10, 2026 at 4:49 AM
Topic: 1999 camaro factory alarm
Posted By: jmj6879
Subject: 1999 camaro factory alarm
Date Posted: September 08, 2004 at 5:10 PM
1999 camaro factory alarm system.  has worked fine since I bought the car, Last night it decides to go haywire. I used to have to hit the lock button twice to arm it. now as soon as the car is locked and the doors are shut, the alarm goes off. it just arms itself and proceeds to go off. so for now I cant lock my car. doesnt matter if I lock it with the key fob or the power door lock button. if anyone can help me here I'd be appreciative. I'm going back out to the car to try to disconnect the shock sensor(bad?) and see what happens.
Jacob
Posted By: auex
Date Posted: September 08, 2004 at 5:15 PM
What the hell is with the camaros lately. Here are isntructions to disable factory security.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: jmj6879
Date Posted: September 08, 2004 at 5:22 PM
Thanks for the info auex but I think I just figured it out, tell me what you think. I just disconnected the shock sensor and everything is back to normal, so I assume it was sending a "I'm getting messed with" signal back. Now, can I safely assume that replacement of this part is all I need to do? what would cause the sensor to go bad in the wee hours of the morning? the light on the sensor was blinking at a high frequency, I'm not familiar with what this is indicating. again any help is appreciated, thanks
Jacob
Posted By: auex
Date Posted: September 08, 2004 at 7:02 PM
Try turning the adjustment knob down before trying to replace it.
