- Output to + Output
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38841
Printed Date: May 10, 2026 at 11:30 AM
Topic: - Output to + Output
Posted By: itchyfishnv
Subject: - Output to + Output
Date Posted: September 08, 2004 at 11:30 PM
Doing my first keyless entry... I have everything all set, my truck has + outputs, so i got a thing that plugs into the brain, that has a relay or box of transistors inside of it to convert from - to + .
My question is I need to do the same thing for trunk release because the output for the trunk release is - is there anyway i could make my own resistor or relay to make it + ????
Posted By: JWorm
Date Posted: September 09, 2004 at 12:03 AM
https://www.the12volt.com/relays/page1.asp
Posted By: sroth140
Date Posted: September 09, 2004 at 12:41 AM
12v to 86, - trigger to 85, 12v to 87, 30 to whatever needs 12v + (output)
MECP certified installer
Date Posted: September 09, 2004 at 1:02 AM
aaaah i c, very simple. thanx
