2003 dodge dakota tach wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39003
Printed Date: March 29, 2026 at 2:32 PM
Topic: 2003 dodge dakota tach wire
Posted By: feyo65
Subject: 2003 dodge dakota tach wire
Date Posted: September 11, 2004 at 10:14 PM
  I need some help on finding the tach wire for a 2003 dodge dakota any help would be aprecciated  thanx
Posted By: Charles_R_H
Date Posted: September 11, 2004 at 10:57 PM
have you done the search on here yet???
you can probably find it behind the gage cluster, sometimes you can even find it in factory radio wiring if the factory deck has road noise compensation
ELECTRONICS RUN OFF OF SMOKE, WHEN YOU LET THE SMOKE OUT THEY STOP WORKING
Date Posted: September 11, 2004 at 11:02 PM
wow, i'm falling asleep!!!! I was telling you about a vss wire!!!!! LOL!!!!
sorry
Date Posted: September 11, 2004 at 11:03 PM
On the 2.5L/3.9L/5.9L models use BLACK/ gray at the ignition coil. The 4.7L models have an ignition coil for each cylinder, use the wire that is NOT GREEN/ orange at one of the coils
Posted By: feyo65
Date Posted: September 13, 2004 at 10:21 PM
thanks is the ignition coil by the distributer
i tried looking for it but couldnt find it (the ignition coil)
Posted By: xtremeaudio
Date Posted: September 14, 2004 at 2:46 AM
can't find tach wire use fuel injecter wire they are the same as list they one or more easy to frind
Posted By: feyo65
Date Posted: September 19, 2004 at 5:55 PM
 i need help in findind the ignition coil on a 2003 dodge dakota . i know the color of the wire i need for the tach , but i cant find the coil. to hook up to.  does any one have any pics of the coil i need . i need to hook up to a black /gray wire at the coil but no luck finding the coil.  thanks........................
Posted By: Teken
Date Posted: September 19, 2004 at 6:26 PM
If you are unable to locate the wire in question. Simply use the wire coming off one of the fuel injectors, use the one that is not common in color to the other ones.
Regards
EVIL Teken . . .
Posted By: feyo65
Date Posted: September 20, 2004 at 9:49 PM
THANX for the help it sounds like i shouldnt have any prob. in finding what im looking for......
