Viper 550esp, 92 Acura Integra 4 Door
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=3901
Printed Date: May 15, 2026 at 2:13 PM
Topic: Viper 550esp, 92 Acura Integra 4 Door
Posted By: joelr7309
Subject: Viper 550esp, 92 Acura Integra 4 Door
Date Posted: September 23, 2002 at 6:12 PM
He there pro's Well I just wanted to ask any who has installed a 550esp Viper Alarm before, I have a 92 Integra 4 dr sedan and saw the 550esp start remote box, wondering if the box is complete, well what I'm asking is, if I buy this Viper 550esp Box. Is it complete with all the components or do I have to buy dio's and resistors to install the alarm, Is there any links that anyone nows to get a diagram to installing a 550esp to a 92 integra. wire link a wire diagram to a 92 integra, THANKS EVERYONE! ------------- THE ROOKIE!~
Posted By: Velocity Motors
Date Posted: September 24, 2002 at 12:26 AM
| 12V|white or wht/blk |+ |ign harness or fusebox | | STARTER|BLACK/ white |+ |ign harness or fusebox | | IGNITION|BLACK / YELLOW |+ |ign harness or fusebox | | SECOND IGNITION|blue/white |+ |ign harness or fusebox | | ACCESSORY|yellow |+ |ign harness or fusebox | | POWER LOCK|GREEN / WHITE |- |either kick panel *1 | | POWER UNLOCK|GREEN/ red |- |same | | PARKING LIGHTS +|RED / green | |steering column | | HEADLIGHTS|RED / yellow |+ |steering column | | DOOR TRIGGER|GREEN/ red *2 |- |dr kick panel/fusebox | | DOME SUPERVISION|use door trigger | | | | TRUNK/HATCH PIN|GREEN/ black |- |dr kick panel/fusebox | |TRNK/HTCH RELEASE|manual | | | | TACHOMETER|blue | |distributor | | SPEED SENSE|yellow/red | |instrument cluster | | BRAKE WIRE|GREEN / WHITE |+ |brake pedal switch | | HORN TRIGGER|blue/red *3 |- |steering column | | WIPERS|blue and blu/yel |- |at switch | | LF WINDOW UP/DN|RED / blu - RED / yel |A |in drivers door | | RF WINDOW UP/DN|blu/grn - blu/yel |A |in drivers door or dkp | | LR WINDOW UP/DN|green - grn/yel |A |in drivers door or dkp | | RR WINDOW UP/DN|yel/grn - yellow |A |in drivers door or dkp | | RADIO 12V|WHITE/ blue |+ |radio | | RADIO GROUND|black |- |radio | | RADIO SWITCH|yellow/red |+ |radio | | RADIO ILLUMINATE|RED / black |+ |radio | | POWER ANTENNA|yellow/white |+ |radio | | LF SPEAKER|blu/grn - gry/blk | |radio | | RF SPEAKER|RED / grn - brn/blk | |radio | | LR SPEAKER|blu/yel - gry/wht | |radio | | RR SPEAKER|RED / yel - brn/wht | |radio | Notes: *1 Easier to locate at passenger kick panel. On drivers side, wires are located high in kick panel. *2 Looks like a 14 awg wire, but is mostly insulation. *3 This wire is high current negative, MUST use relay. https://www.the12volt.com/downloads/file.asp?ID=266 For the 550ESP installation manual. ------------- Jeff
Date Posted: September 24, 2002 at 10:39 AM
HEY JEFF Your one Helpful PErson, I see you know your stuff, thanks for the info, I read a couple of article in here and your always the one to respond to there needs, Well I just wanted to say thanks! O do you know about my other question, If I buy the 550esp remote start, is it complete with everything, or do I need to buy any dio's or resistor to make the REmote Start work, or complete the installation to the alarm, PROP's On Jeff, ------------- THE ROOKIE!~
Date Posted: September 24, 2002 at 8:54 PM
You need nothing else for the car & alarm system, but you do need patience and a good deal of time for any installation that you are not familiar with. Good luck and you know where to come if you need some help  ------------- Jeff
Posted By: cpgoose
Date Posted: September 25, 2002 at 2:08 PM
Hey man, just to add on here...if you look at Page 25 of the Installation Manual, you might need some relays depending on what type of door locks you have. But since you have an Integra (someone correct me if I'm wrong), you'll probably have Type-B....in which case you won't need any relays.
Date Posted: September 26, 2002 at 12:51 AM
The Integra uses a type A (-) trigger door lock system. Type B is a positive type system. No relays required. ------------- Jeff
