Clifford concept 40 install help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39124
Printed Date: April 01, 2026 at 8:58 AM
Topic: Clifford concept 40 install help
Posted By: sictruck
Subject: Clifford concept 40 install help
Date Posted: September 14, 2004 at 11:41 AM
this is my first alarm install and i need help.  im installing clifford concept 40 into my 99 jeep cherokee, and i got everything but the door lock, unlock to work.  why won't the doors unlock or lock?  i was a little cofused by the alarm wires.  it has door lock comm., door unlock comm.,  door unlock n.c., door lock n.c., and door lock n.o., and door unlock n.o., which ones do i use?  any relays need?
Posted By: cosmoworks
Date Posted: September 14, 2004 at 6:28 PM
Looks like your car is negative trip:
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1999&make=Jeep&model=Cherokee&ID=18136&type=Alarm
Tape off both n.c. wires ... you don't need them. Then connect both comm wires to ground. Then use the n.o. wires to trip the doorlocks.
Your welcome again posted_image
Posted By: sictruck
Date Posted: September 14, 2004 at 11:13 PM
yeah i did some trial and error today and i figured that out.  thanx
