2002 Civic EX wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39255
Printed Date: April 03, 2026 at 3:53 PM
Topic: 2002 Civic EX wiring
Posted By: krayzie2k3
Subject: 2002 Civic EX wiring
Date Posted: September 16, 2004 at 9:49 PM
so far, i have found the wiring diagram. what im curious is about using the DEI 555U, the immobilizer. is that needed for a normal alarm such as the Clifford Arrow 5? i dont need remote start or anything. thanks https://www.the12volt.com/installbay/forum_posts.asp?tid=5678&KW=2001+civic
Posted By: hagmanti
Date Posted: September 16, 2004 at 10:04 PM
No, the only reason you'd need to bypass the immobilizer is if you wanted to be able to start the car w/o a key in the ignition.
Me
Date Posted: September 16, 2004 at 11:03 PM
so i have a 02 civic ex 5spd mt. so i have no need? basically the point someone would get a immobilizer is for the remote start option? thanks
Posted By: hagmanti
Date Posted: September 18, 2004 at 12:18 AM
The immobilizer is built into your car. The key sends out a (coded?) RF signal that the computer interprets, and won't start w/o. Thus, the car "can't" be jumpstarted.
If you're trying to install a remote start, you need an immobilizer bypass-- this is some electronics that either sends that signal, or uses an extra key to send that signal whenever the remote start is activated.
So, you already have an immobilizer, and the only reason you'd need a bypass for that immobilizer is if you were installing a remote start.
Me
