Alarm LED
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39282
Printed Date: April 04, 2026 at 6:37 AM
Topic: Alarm LED
Posted By: amp583
Subject: Alarm LED
Date Posted: September 17, 2004 at 2:16 PM
Im a newb so go easy on me...
I have a 95 chrysler cirrus with factory alarm/starter disable. i would like to add a blinking LED that flashes when the alarm is activated. Where would i wire the LED to and, on a side note, will any radioshack LED do or should i invest in a super dooper bright one.
Posted By: thepencil
Date Posted: September 17, 2004 at 2:41 PM
Bottom line is you pay for what you get, so spend it on a good quality led that can handle 12 volts.
“i would like to add a blinking LED that flashes when the alarm is activated”
To wire it up, ground the negative side of the led to the starter kill wire on the alarm and the positive side of the led to a constant 12 volts.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: kel789
Date Posted: September 17, 2004 at 11:03 PM
curious, what size is the compustar fm LED. i need to drill a hole to make it fit. how do i find out?
