’04 GTO Security Bypass on Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39481
Printed Date: April 08, 2026 at 10:25 PM
Topic: ’04 GTO Security Bypass on Remote Start
Posted By: XFACTOR1
Subject: ’04 GTO Security Bypass on Remote Start
Date Posted: September 21, 2004 at 12:18 PM
Has anyone done one of these yet, if so what part did you use to get around the new key system. It has a laser cut key. Any info would be good on this car just doing some research before I start these. Have 4 of them to do remote starts on as soon as I have more info.
Thanks,
Chris
Posted By: another-kelly
Date Posted: September 21, 2004 at 8:40 PM
according to techsoft:
Pontiac, GTO, 2004
Required: YesPart#: N/AType: No Info
Notes: No information available at this time
Posted By: mo12v
Date Posted: September 21, 2004 at 8:50 PM
GTO 2004
WIRE COLORSLOCATION
12 VOLTS CONSTANT  BATTERY
IGNITION 1ORANGE (+)IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER BROWN / WHITE (+)( 2 wires use only 1 )IGNITION SWITCH HARNESS
STARTERPURPLE (+)IGNITION SWITCH HARNESS
PARKING LIGHTS ( + )BROWNat the FUSE BOX or in the PASSENGER KICK PANEL
DOME LIGHTGRAY/WHITE ( - )at the BCM, 26 Pin plug Pin 19 See NOTE**
DOOR TRIGGERGRAY/WHITE AND WHITE ( - )at the BCM, 26 Pin plug Pin 19 and Pin 4 See NOTE**
POWER DOOR LOCKBROWN / WHITEat the BCM, 26 Pin Plug Pin 17 See NOTE**
POWER DOOR UNLOCKLT. GREEN/ YELLOWat the BCM, 26 Pin Plug Pin 16 See NOTE**
TACH SENSORBROWN / REDat the PCM, located on the DRIVERS SIDE FENDER, UNDER COOLANT RESERVOIR, in  a GREEN Plug Pin10
BRAKE
BLUE/RED (+)at the BRAKE SWITCH
TRUNK RELEASE BLACK/ RED ( - )at the BCM, 16 Pin Plug Pin 8  See NOTE**
TRUNK TRIGGERYELLOW /GREEN   ( - )at the BCM, 26 Pin Plug Pin 6   See NOTE**
HOOD TRIGGERRED / WHITE ( - )at the BCM, 12 Pin Plug Pin11 See NOTE**
HORNBLACK / YELLOW    ( - )at the  BCM, 22 Pin Plug Pin17 See NOTE**
ALARM DISARMwith FACTORY REMOTE ONLY
FACTORY  ANTI-THEFT
TYPEWILL NEED KEY
NOTE**       The BCM (Body Control Module) is BEHIND the GLOVE BOX just below the BLOWER
Until NEW Updates come in this is all I have.
MO
Posted By: JWorm
Date Posted: September 22, 2004 at 12:01 AM
Check out
https://www.bypasskit.com
and see if they have any bypass modules for it.
The GTO is a Pontiac, correct?
Posted By: JWorm
Date Posted: September 22, 2004 at 12:07 AM
laser cut, you sure?
Take a look at a key....see if it says "PK3" or "PK3+" on the metal part.
Any idea who actually makes the car? The wire is really different than any other GM car right now.
Posted By: wchavez
Date Posted: September 22, 2004 at 12:14 AM
It's a Holden Monaro, an austrailian car. The only thing I've seen in schematics is a 'PURPLE / red ignition key resistor ' wire listed at the bcm. Definitely need to work on one.
