04 Chrysler Sebring conv. alarm/remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39518
Printed Date: April 09, 2026 at 8:35 PM
Topic: 04 Chrysler Sebring conv. alarm/remote start
Posted By: lamountain
Subject: 04 Chrysler Sebring conv. alarm/remote start
Date Posted: September 21, 2004 at 10:48 PM
Looking for wiring diagram for a 2004 Chrysler Sebring conv.
Instaling remote starter with alarm
Date Posted: November 21, 2004 at 2:14 PM
I am having problems with the door pin. I am pluging in to the c4 connector at BCM using the tan and tan/red with diodes .With a volt metar it reads "0" with the door open, that is "ok" after i close the door it reads 11.xx volts after the inside lights go out 5 sec. later it reads 5.xx and gives me a door open alarm.
How do correct this problem, do i use a resister or plug in to the inside light with a relay?
Posted By: draasch
Date Posted: November 21, 2004 at 2:57 PM
see if this helps.....
Dome Light BLACK/ WHITE (-) HARNESS TOP OF FUSE BOX
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
