What Alarm Do I Have?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39526
Printed Date: April 10, 2026 at 4:08 AM
Topic: What Alarm Do I Have?
Posted By: tecca
Subject: What Alarm Do I Have?
Date Posted: September 22, 2004 at 12:24 AM
I'm farly new to the alarm industry, so bare with me. I bought a 1994 Mustang. When i bought they said, to their knowlege, they didnt think there was an alarm on it. After looking around a bit i found what looks to be an alarm system. They keys are not the orginal, nor do they have a keypad on them. The only info that i have found on any of the hardware were there Model #'s and Serial #'s. I have looked around and cannot find any results...
Model #: PEUP-3CH.-PB.V.3
Serial #: 80582
Made in the U.S.A. 12-1995
Any Idea's????
------------- Love, Peace, And Chicken Greese
Posted By: Teken
Date Posted: September 24, 2004 at 5:32 PM
Open the unit, or give us the FCC ID on the remote control unit.
Regards
EVIL Teken . . .
Posted By: tecca
Date Posted: September 24, 2004 at 8:56 PM
I dont have the remote, that half the reason for my search for a manufacturer. I will open the unit up tomorrow, and giva ya guys an update. Thanks.
Posted By: tecca
Date Posted: September 27, 2004 at 10:40 AM
F8AB-15K601-AA
FCC ID: CWTWB1U313
CAN: 1788 102 352
Posted By: tecca
Date Posted: September 27, 2004 at 12:48 PM
The Unit itself
The Remote
Posted By: Teken
Date Posted: September 27, 2004 at 3:12 PM
It would be nice if you could write out what is written on the back of the unit, as there may be some words / phrases that might job my memory.
The key fob sure looks like a OEWM unit, but then again that doesnt mean much.
Open the unit, there will be something in there.
Regards
EVIL Teken . . .
Posted By: tecca
Date Posted: September 28, 2004 at 12:41 AM
Inside:
"PIC16C57-RC/P
9534CDW Microchip"
Outside:
RED (= 12V. MAIN POWER INPUT)
WHITE/ ORANGE (PARKING LIGHT OUTPUT +12V.)
ORANGE (SIREN OUTPUT +12V .3AMP)
GREEN/ BLACK (LOCK NEGITVE PULSE)
YELLOW (UNLOCK NEGATVE PULSE)
GRAY (STARTED KILL NEGATIVE OUT)
RED / BLACK (LED NEGATIVE PULSE)
WHITE/ YELLOW (DOME LIGHT NEGATIVE PULSE)
BLUE (NEGATIVE TIGGER FOR SENSOR)
VIOLET (VALLET NEGATIVE INPUT)
GREEN (SWITCHED 12V. ACC.)
BLACK (SYSTEM GROUND)
WHITE (DOOR TIGGER POSITIVE)
BLUE/WHITE (DOOR TIGGER NEGATIVE)
__________________________________________________________________
2 PIN CONNECTOR
WHITE/ RED (3RD CHANNEL AUX. NEGATIVE OUTPUT)
BROWN (2ND CHANNEL NEGATIVE OUTPUT)
___________________________________________________________________
SWITCH SETTINGS
1 OFF - 3 SECOND DOOR LOCK/UNLOCK
2 OFF - IGNITION AUTO LOCK/UNLOCK OFF
3 0FF - DOOR WILL NOT LOCK IN PASSIVE
4 OFF - ACTIVE ONLY
I also grabbed another remote. A black Verson of the remote displayed above.
Black Remote: 2s4t - 15k601 - aa
Gray: f8ab - 15k601 - aa
Posted By: swamprat323
Date Posted: September 28, 2004 at 7:39 PM
That is the factory keyless entry or alarm system, it is made by ford. What do u need to know about it.
Posted By: Velocity Motors
Date Posted: September 28, 2004 at 9:47 PM
That is not the OEM alarm system. I have never seen a OEM system that has the wiring diagram embossed on the back side of the CPU.
------------- Jeff
Posted By: tecca
Date Posted: September 29, 2004 at 12:28 AM
Can you guys find some info on the system?
Serial #: 80582
The system also has a shock sensor with it. I just need to know how to program keypads to match that system. Other than that i can hook it up. When it says "negative pulse" does that mean the negative wire, or something else. I think i know what i means, but not sure how to explain it.
Posted By: tecca
Date Posted: September 29, 2004 at 12:40 AM
Ps. Also would 1994 Mustangs come stock with Vallet Switch?
Posted By: tecca
Date Posted: September 29, 2004 at 12:48 AM
Im sorry, i dont mean to post spam here, just dont know how to edit posts yet. There is also a LED installed right under my head light switch, that goes to that unit, I assume that it indicates wether the system is active or not.
Posted By: davedyer79
Date Posted: September 29, 2004 at 9:22 AM
I think this is a code alarm that is a DEALER add-on. Code makes ford keyless, and they also sell OEM style alarms for the car lots to install at the dealership. Usually (9 times out of 10) a certified mechanic installed the alarm, which is pretty scary. Most the time they love to use the t-taps and stuff things anywhere just to get the car out of the bay. Go to Code's website (www.codl.com) and see if they can tell you anything. Good luck, David Peace, Love, and Honeybuns ------------- davedyer79
Posted By: tecca
Date Posted: September 29, 2004 at 11:43 AM
Well i reconnected the main power to the unit, and i got the vallet mode to engage and disengage. Is there a way to program the keypads that i have to the system? or engage the alarm w/out a keypad? PS i also sent a message to the code alarm people in hopes they might know who made it, or what to do with it.
Posted By: tecca
Date Posted: September 29, 2004 at 2:26 PM
OK, my alarm is officaly in crack mode. I got the Vallet mode to work. I then some how armed the system. when i touched the shock sensor, of course it went off. Now i cant seem to get it to shut off. i unpluged the unit, the siren, and everything. When i put it back together, The alarm is still on, but is very quite. The car will still go into vallet mode as normal, just the alarm is going off!!  Grrrr.
Is there a way a programed the lock button on the keypad, but no others? ------------- Love, Peace, And Chicken Greese
Posted By: Teken
Date Posted: September 30, 2004 at 3:08 PM
The unit is made by Alps electric Co. Ltd. It is made in Japan, and is also a OE maker.
Regards
EVIL Teken . . .
