RS install question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39666
Printed Date: April 13, 2026 at 11:30 AM
Topic: RS install question
Posted By: MikeHusain
Subject: RS install question
Date Posted: September 24, 2004 at 9:47 AM
I am going to install an autopage 850 rs in a maxima and I noticed that it has two accessory wires and 1 ign wire. The RS unit has two ing wires and 1 accessory wire.  Could I take the second ign wire coming from the RS unit and use it as a second accessory wire that the vehicle needs.  I wont use it as the heator blower motor, I am assuming the second accessory wire in the 2003 maxima is for the radio????   Do I even need to hook up the second acessory wire in the max?  I heard its best to power everything up just as the key does when turning the ign.  Thanks....
Posted By: snguyen
Date Posted: September 24, 2004 at 6:38 PM
I only remember that the 2003 nissan maximo only have one accessory wire.   (red)
Posted By: Velocity Motors
Date Posted: September 24, 2004 at 8:46 PM
You can' t use the 2nd IGN from the to power the 2nd ACC wire. These wires have different characteristics and output a 12 volt signal at different intervals of the key cylinder. Here is the wire colors and also the relay configuration to power up the 2nd ACC :
IGNITION|BLACK / YELLOW        |+  |ignition harness
ACCESSORY|red                 |+  |ignition harness
SECOND ACCESSORY|WHITE/ blue          |+  |ignition harness
Date Posted: October 05, 2004 at 3:01 PM
I looked at the second accessory wire relay configuration, but I was wondering wouldnt it be better to ground pin 86, fuse 12 volt constant to pin 87, tap into accessory wire from alarm brain to pin 85, and out put to 2nd accessory wire using pin 30?  This is just an idea I had, I am sure you are absolutley right due to the fact that you have been doing this for a numerous amount of years.  Could you give me somefeed back about my possible 2nd accessory wire relay?  Thank you and I appreciate your time... Mike....
