Remote Start 97’ Ranger
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39742
Printed Date: April 16, 2026 at 3:45 PM
Topic: Remote Start 97’ Ranger
Posted By: pantherfan_03
Subject: Remote Start 97’ Ranger
Date Posted: September 25, 2004 at 7:22 PM
Hi guys,
I know there are a lot of posts about rangers but nothing I have tried has worked. I have properly connected the starter wires through the relay along with the starter kill and ignition. I even disconnected the starter kill wire to see if that was causing my truck not to start remotely. I connected the tach wire to the tan / YELLOW wire under the hood on the drivers side. That seems fine because the alarm recognized it. I only have one acc. wire going to the acc. in the wiring harness. I have another acc. coming from the alarm but I don't know if i need it. The lights flash like they should when I press the start button, but it won't even attempt to start. I don't know what the neutral safety switch is because my ranger wiring guide doesn't give me the color scheme. Can anyone please help I have been fighting this alarm for 2 days now.
My Alarm is the Crimestopper CS-2016FM.
Thanks in Advance,
Josh
Posted By: Velocity Motors
Date Posted: September 25, 2004 at 8:38 PM
IGNITION|GREEN/ purple        |+  |ignition harness
ACCESSORY|gray / YELLOW   (x2)  |+  |ignition harness
SECOND ACCESSORY|BLACK/ green         |+  |ignition harness
Here are the ignition wires you need and also, you didn't mention if the truck was a std or auto ?
Date Posted: September 25, 2004 at 10:55 PM
The truck is auto, and I have all of the color schemes of all the wires, but I am not sure if I have to also hook up the 2nd ACC./IGN. wire. It says "if necessary." That is the only wire I do not have hooked up. Do I need to connect it through a relay or just hardwired. Does that Neutral Safety have anything to do with this problem.  I believe the tach I chose is correct because the lights blinked like they should have but it wouldn't let me program it into the remote.
Date Posted: September 25, 2004 at 11:35 PM
Is your brake switch hooked up correctly and what wires did you tap into to get the ing?
___________________________________________
Cruisin Security And Sounds
I GOT IT! Thanks to CruisinS&S and this post a while back.  Thanks a lot bro. And thank you Velocity Motors for your support and for believing in me...lol
Anyways Appreciate the help,
Josh
