Windstar 95
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39860
Printed Date: April 18, 2026 at 6:12 AM
Topic: Windstar 95
Posted By: Charlot888
Subject: Windstar 95
Date Posted: September 27, 2004 at 6:39 PM
I need diagram for install remote start on Windstar 95. Thanks
Posted By: Teken
Date Posted: September 27, 2004 at 6:42 PM
Ford
Windstar
1995
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
WHITE/ PINK OR
RED / LT BLUE IGNITION SW. HARN. *
Ignition #1:
RED / LIGHT GREEN
IGNITION SWITCH HARNESS
Ignition #2:
GRAY / YELLOW (# AWG)
IGNITION SWITCH HARNESS **
Ignition #3:
GRAY / YELLOW-2WIRES
Accessory:
BLACK/ GREEN
Brake Light:
RED / GREEN
(+) AT SWITCH NEAR UPPER BRAKE PEDAL
Tach Signal:
WHITE/ PINK
IGNITION CONTROL MODULE *
Parking Lights:
BROWN (+) AT DRIVER
KICK PANEL OR BLACK/ WHITE AT LIGHT SW
Headlights:
RED / YELLOW (+)
HEADLIGHT SWITCH OR BEAM SELECT SW.
OEM Alarm Disarm:
DARK GREEN/ PURPLE
(-) IN EITHER KICK PANEL
OEM Alarm Arm:
N/A
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* Ignition Control Module (ICM) Located: (3.0L) On Passenger Firewall. (3.8L) Behind Washer Reservoir On Passenger Side. ** See Note #127- Ford Ignition Switch Connection Diagram.
Ford
Windstar
1995
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
3 YELLOW & 1 BLACK/ ORG
Starter Kill:
WHITE/ PINK OR
Ignition +12 Volts:
RED / LIGHT GREEN
Dome Lights/Superv:
BLACK/ LIGHT BLUE (+)
DRIVER KICK PANEL OR AT PIN SW.
OEM Horn:
YELLOW/LIGHT BLUE (-)
STEERING COLUMN HARN. OR AT RELAY
Power Lock:
PINK / YELLOW
DRIVER'S KICK PANEL ***
Power Unlock:
PINK/LIGHT GREEN
Trunk Release:
N/A
Alarm Input Wire:
Notes:
* With OEM Alarm- RED / L BLUE. Without OEM Alarm- WHITE/ PINK. ** Courtesy Light Relay Located At Fuse Block Behind Left Side Of Dr. Dash. *** Without OEM Keyless Entry See Note #203 - Reverse Polarity Door Lock Diagram, With OEM Keyless See Note #202 - Positive Pulse Door Lock Diagram.
Posted By: Teken
Date Posted: September 27, 2004 at 6:47 PM
Date Posted: September 27, 2004 at 7:12 PM
Thank you Teken ------------- André, Ford specialist
Posted By: Teken
Date Posted: September 27, 2004 at 7:18 PM
DIRECTWIRE™ WIRING INFORMATION - FORD / WINDSTAR / 1995 / Remote Start
12volts yellow + ignition harness
Starter wht/pnk or RED / blue + ignition harness
Second Starter
Ignition RED / green + ignition harness
Second Ignition BLACK/ green + ignition harness
Third Ignition
Accessory gray / YELLOW + ignition harness
Notes: May be more than one - test to verify which one powers blower and A/C controls.
Second Accessory BLACK/ pink + ignition harness
Keysense
Power Lock pink / YELLOW - drivers kick panel
Notes: The keyless module is behind center storage compartment.
Power Unlock pink/green - drivers kick panel
Lock Motor
Unlock Motor
Parking Lights+ WHITE/ black light switch
Notes: One of two, only one is pkg lt.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger BLACK/ blue + kick panel
Dome Supervision
Trunk/Hatch Pin common with doors
Hood Pin black - at sw under hood
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm GREEN/ purple - either kick panel
Disarm No Unlock
Tachometer gray/orange AC EDIS module
Notes: Six-cylinder EDIS module on passenger side fender wall underhood.
Wait to start
Brake Wire RED / lt. green + brake pedal switch
Parking Brake
Horn Trigger YELLOW /GREEN - ignition harness
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
Posted By: Teken
Date Posted: September 27, 2004 at 7:22 PM
WINDSTAR 1994-1998
WIRE COLORS LOCATION
12 VOLTS CONSTANT YELLOW (x3)
IGNITION 1 RED / LT GREEN (+) IGNITION SWITCH HARNESS
IGNITION 2 GREEN/ BLACK (+) IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER GRAY / YELLOW (+) IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER BLACK/ PINK (+) 98 only IGNITION SWITCH HARNESS
STARTER RED / LIGHT BLUE (+) or WHITE/ PINK (+) IGNITION SWITCH HARNESS
PARKING LIGHTS (+) WHITE/ BLACK (2) wires test to see which one is the parking light wire. at HEADLIGHT SWITCH
DOME LIGHT BLACK/ BLUE (+) IN DRIVERS KICK PANEL
POWER DOOR LOCK PINK / YELLOW in DRIVERS KICK PANEL (TYPE "C") See NOTE*
POWER DOOR UNLOCK PINK/LT GREEN in DRIVERS KICK PANEL (TYPE "C") See NOTE*
TACH SENSOR See NOTE**
BRAKE
RED / LIGHT GREEN (+) at BRAKE SWITCH
HORN
YELLOW /GREEN (-)
at STEERING COLUMN HARNESS
FACTORY DISARM
GREEN/ PURPLE (-)
in EITHER KICK PANEL
NOTE* If equipped with FACTORY KEYLESS ENTRY the door locks are TYPE "B", without FACTORY KEYLESS ENTRY the door locks are TYPE "C".
NOTE** On the 3.0L engine the TACH wire is a YELLOW/BLACK. On the 3.8L engine the TACH wire is a DARK BLUE/LIGHT GREEN. To locate these wires follow the spark plug wires back to the coil pack on both engines.
Please ensure you review all three sources for reference, should there be a discrepency. Verify all connections points with your DMM, prior to final installation.
Regards
EVIL Teken . . .
