Wiring Info for 04 Jeep Grand Cherokee
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39865
Printed Date: April 18, 2026 at 6:12 AM
Topic: Wiring Info for 04 Jeep Grand Cherokee
Posted By: jmr964
Subject: Wiring Info for 04 Jeep Grand Cherokee
Date Posted: September 27, 2004 at 7:52 PM
If someone would be so kind to link me the info for the directwire info for a 2004 Jeep Grand Cherokee I would greatly appreciate it.  I had this posted a while ago back in the vehicle wiring info forum but no one replied.
Jason
Posted By: Teken
Date Posted: September 27, 2004 at 7:59 PM
DIRECTWIRE™ WIRING INFORMATION - JEEP / GRAND CHEROKEE / 2004 / Remote Start
12volts red & pink/black   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition dk. blue   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory RED / black   +   ignition harness
Second Accessory BLACK/ orange   +   ignition harness
Keysense
Power Lock ORANGE / black - ORANGE / purple   5wi door lock switches
Notes: Use ORANGE / black and pink/black at the driver door lock switch to lock and unlock the driver door. Use ORANGE / purple and pink/purple at the passenger door lock switch to lock and unlock all of the other doors.
Can also use Directed part 455J door lock interface control module. This will control door lock, unlock, arm disarm, dome light supervision and more.
Power Unlock pink/black - pink/purple   5wi door lock switches
Lock Motor ORANGE / black   5wi driver door lock switch
Unlock Motor pink/black   5wi driver door lock switch
Parking Lights+ do not use
Parking Lights- yellow   -   headlight switch
Notes: Parking lights require a negative trigger thru a 1300 ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch.
Hazards dk. blue/pink   -   steering column
Notes: The hazards will flash even with a latch input to the wire.
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger see notes   -
Notes: The driver door trigger is tan/red at the driver door lock switch. The passenger door is tan/red at the passenger door lock switch. The driver rear door is tan/orange and the passenger rear door is tan / YELLOW at the BCM. Use all four wires and diode isolate each.
WHEN USING A 455J INTERFACE MODULE, IT IS NOT NECESSARY TO USE THE SEPARATE TRIGGER WIRES. USE THE YELLOW WIRE AT THE UNDERDASH LIGHT FOR DOOR TRIGGER.
Dome Supervision yellow/dk. green   -   BCM, above diagnostic plug
Notes: Can also use Directed part 455J door lock interface control module. This will control door lock, unlock, arm disarm, dome light supervision and more.
Trunk/Hatch Pin tan/black   -   BCM, above diagnostic plug
Hood Pin
Trunk/Hatch Release
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm lt. GREEN/ orange   -   driver door lock switch
Disarm No Unlock
Tachometer see notes   ac
Notes: The 4.7L motor has a separate coil for each cylinder. Go to any coil and use the wire that is NOT dk. GREEN/ orange. On the 4.0L use any of the tan/stripe wires at the coil pack, or go to one of the fuel injector and use the wire that is NOT dk. GREEN/ lt. green.
Wait to start N/A
Brake Wire WHITE/ tan or PURPLE / brown   +   driver kick panel
Parking Brake
Horn Trigger gray/orange   -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: Sentry Key Part #: 555C, 556U, or 555U
Notes: Only vehicles with gray keys have the immobilizer.
Posted By: Teken
Date Posted: September 27, 2004 at 8:01 PM
https://www.directechs.com/guides/manuals/ig/accessories/N556U_09-04.pdf
The link provided above is for the DEI 556U bypass module.
Regards
EVIL Teken . . .
Posted By: jmr964
Date Posted: September 27, 2004 at 8:09 PM
Thanks for the info.  I had my Viper 550ESP installed in my 03 Grand Cherokee but it got replaced with an 04 a few months back because of the lemon law.  I pulled the 550ESP out and will be putting it in the 04 soon.  I am using the 555C bypass for the immobilizer.
Today I finished installing my 791XV in my 04 Dodge Dakota.  That works really well.
Jason
Posted By: JWorm
Date Posted: September 27, 2004 at 9:19 PM
I don't believe it is possible to reuse a 555C on a second vehicle. You will probably need to buy a new one.
Posted By: Velocity Motors
Date Posted: September 27, 2004 at 9:22 PM
That is correct. Once a module from Jeep or Chrysler has been programmed, you can not use this in another vehicle with the Sentry System.
Posted By: jmr964
Date Posted: September 27, 2004 at 9:24 PM
I thought that might be the case so off to ebay for another 555C unless someone here has one they can dump cheap.
Jason
